switching 3.1 V6 to 350 gen 1 vortec
Engine: soon to be changed 3.1
Transmission: soon to be changed 700R2
Im in the process of swapping my V6 for a 350 vortec. i have heard good things about the stock vortec heads, except that they can't handle much lift. so that puts me in a bind with my cam choice since the lift will be a little over .500. i kinda want to keep the steel vortec heads, but need advice on if there is a spring kit or head kit that i can buy to make the vortec heads accept the lift i want to reach??
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: switching 3.1 V6 to 350 gen 1 vortec
you can easily have the heads machined to handle more lift...
Thanks for the advice. do you have any opion on the steel vortec heads?
Car: 91 Camaro RS
i run a set of iron vortecs on my stroked 389 and love them. they wer machined for the higher lift of my cam
Car: 91 Camaro RS
just remember, if youre building the motor yourself, youll need a vortec specific intake, the vortec heads use taller intake runners, so regular intakes dont fit.
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
yep, since the motor is not installed, pull the heads and have them properly machined for higher lift. Probably want to have screw in rocker studs installed too.
I love my iron vortecs. They really surprised me.
FormulasOnly
Sep 10, 2015 09:07 PM
