83 trans am 350 crate swap help!
Old Apr 20, 2010 | 06:03 PM
83 trnsam's Avatar
Car: 1983 trans am/70 dodge dart
Engine: 305 TBI soon to be 350 TBI
Axle/Gears: 10 bolt posi, 3.23
Ok, so i am going to install a gm performance 350 crate engine into my car in the near future. I really want to use my factory cfi from my 305( crossfire injection), what i dont know is if it is a direct swap or do i have to get it rejeted? And if i do how big should it be jetted out to? Also i have heard a lot of mixed feelings on my tranny,700r4 that it can only handle up to 300 horses. Is there a rebuild kit or anything that might make it more durable to handle up to at least 330 horsepower or should it be fine without doing anything to it? Any advice or ideas would be greatly appreciated, keep in mind that i am only 19 and dont have a lot of money to put into it thanks.
Old Apr 20, 2010 | 06:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
First, welcome aboard thirdgen.org.
Second, I moved this to the Engine Swap forum because it really isn't a Carburetor topic.
Understand I've never dealt directly with CFI, but from what I understand, it is more like TBI than anything else, so you might find as good or better help on the TBI forum.
I also understand that the Vette 350 CFI parts can be used to upgrade f-body CFI when you go to a larger than 305 engine. But, the aftermarket never really got into the CFI stuff, so upgrades beyond that are very limited. At least one TGO member had a 400 under a CFI, so it's not like it's complete un-doable.
Which GM crate engine were you considering?
Keep an eye out on eBay, Craigslist, RacingJunk, etc., for Vette parts. And, you might want to take a gander over in the TBI forum to see if there is any help for you there.
Old Apr 20, 2010 | 07:33 PM
83 trnsam's Avatar
Re: 83 trans am 350 crate swap help!
Thanks, i am going to install the gm performance 350 ho crate engine.
As far as the Tbi i will just swap them out for vette ones, seems like the cheapest route. I am also goin to put a rebuild kit into my tranny and a vette servo because i really dont want it to blow up. that's never any fun!
thanks for the input, much appreciated!
Old Apr 20, 2010 | 07:55 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
No no no, don't get that one. You're paying more to get less. If you want the hassles of trying to fit Cross Fire to Vortec heads, then get p.n. 12530282. It's $2200. It's the same block, crank, rods, pistons and heads as the 350 HO, but it's cheaper, plus it includes the roller lifters and stuff.
Old May 8, 2010 | 07:25 PM
wddavis's Avatar
Car: 83 z28/ 82 trans am
Engine: stock? 305 w/crossfire
Axle/Gears: 3.73/stock 2.98?
just install vette injectors into your t-bodies, you may also want to change the prom inside the computer, I have seenat crossfireinjection.net they have a prom for less than 80 bucks, the injectors and the prom are the only difference between the 5.0 f-body and the 5.7 vette.
Old Mar 13, 2011 | 11:42 PM
Javier's Avatar
Car: 1983 Pontiac Trans Am
Engine: 5.0 Crossfire Injection
Transmission: 700 4R
Axle/Gears: 4.10
any updates on your build? this sounds like a great option for more horsepower.
updates and pics ?
Old Mar 14, 2011 | 10:16 AM
torque_is_good's Avatar
updates and pics ?
I wouldn't hold my breath, he hasn't posted for 11 months.
What I've found on many automobile forums is that the majority (over 50%) of planned builds/upgrades/swaps never happen.
Try the search feature for swaps that really happened
Old Mar 14, 2011 | 11:37 AM
Javier's Avatar
Axle/Gears: 4.10
will do thx!
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
mizz0313
Aug 12, 2015 06:45 AM
