Stock TPI base modded for Vortec questions
Old Mar 13, 2011 | 12:51 AM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
I have a modded stock tpi base and I was wondering if anyone knows if you can still run the EGR set up. If not, do I just need the "delete" plate or is there more ports to block?
Old Mar 13, 2011 | 01:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Stock TPI base modded for Vortec questions
Vortec heads don't have the heat riser so if you need EGR have to use a ext source like the Vette TPI setup
The EGR delete plate would be all that's required to seal the EGR valve hole
Old Mar 14, 2011 | 01:10 AM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Attached Thumbnails Stock TPI base modded for Vortec questions-downsized_image03102011181153.jpg   Stock TPI base modded for Vortec questions-downsized_image03102011181119.jpg
Old Mar 14, 2011 | 09:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
To be clear, is this an aftermarket TPI base for Vortec heads, or did someone take a stock TPI base, weld material to it, and remachine it?
You can get a kit that mounts to the Vortec TPI base that brings exhaust gases from the exhaust manifold/header to the base and makes the EGR functional. Check out www.sdparts.com, p/n SD3816 (you may have to call them - searching their site for the p/n only came up with the TPI Vortec base).
Or, get/make a block-off plate for the valve mount boss.
Old Mar 15, 2011 | 01:35 AM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Thank you, plate was ordered (for now till smog time)
Old Mar 15, 2011 | 01:37 AM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
This is a stock tune port base, machined to work with the vortecs, material was added to it
Old Mar 15, 2011 | 01:42 AM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Im looking for a corvette set up (pictures) and I cant find anything. My headers have the port to run the egr set up from sdparts.com but where would the other end run? (since this isnt the "vortec casted tpi base"
Old Mar 15, 2011 | 02:17 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Vette TPI base with EGR entry at rear
Vortec TPI Base used same arrangement
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
marcusaw
Aug 10, 2015 08:13 AM
