Engine removal
Old Mar 15, 2011 | 05:39 PM
Hiball8's Avatar
Car: 1990 formula 350
Axle/Gears: 3.23 posi
Engine removal
I have a 1990 formula 350, l98 TPI. The engine is is blown the p/o threw a rod. The engine is ready to pull out except for the torque converter. I can't get the engine to turn to get the bolts out . Is it possible to pull the engine with the t/c still attached or pull both engine and trans together loosen the crank bolts to get the t/c to turn and get the bolts out. Thanks in advance for any help.
Old Mar 15, 2011 | 05:49 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
Re: Engine removal
Actually the majority of the guys on here pull the engine and transmission together. I've done it both ways, each has its own challenges.
I'm trying to imagine whether or not the tc would get hung up on the bellhousing if you tried to pull the engine with it still bolted to the flexplate. You'd definitely have to put a jack under the front of the trans and raise it until it hits the underbody, lifting the engine equal amounts and using a leveler to keep the angle right. Then maybe the motor mounts would be high enough to clear to pull the engine straight forward.
I bet that once the transmission is removed from the engine with both out of the car, you'll then be able to just unbolt the tc from the top and sides since the bellhousing wont be in the way anymore.
Old Mar 15, 2011 | 07:50 PM
torque_is_good's Avatar
Re: Engine removal
I belong to the "yank the engine and tranny together" club.
It's just so much easier to connect them back together out of the car and you can replace the tranny mount and seals on the tranny while it's out.
Old Mar 15, 2011 | 08:53 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: Engine removal
Jack up the rear of the car like 25+" and then the engine/trans comes out at an angle keeping the tail of the trans from hitting the ground. It's the best time saving tip I've learned from a friend of mine. Taking out the radiator and fans helps too I think. This way you don't even have to remove the engine.accessories. installation is the same also. It's so fast this way! I even have the trans lines on the trans while the engine/trans is being installed. Hate being under the car working with trans lines!
Old Mar 15, 2011 | 09:07 PM
Hiball8's Avatar
Re: Engine removal
Thanks for the incite, the guy I got the car from started the tear down so the top of the engine, acc,rad have already been removed. So I will pull them out together. Thanks again for the help.
Old Mar 16, 2011 | 02:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by Hiball8
Thanks for the incite...
(I'm not trying to incite anything, but you need to learn the difference between "incite" and "insight"...)
I'm with the "pull them together" crowd. Much easier, in my opinion, to split them after both are out, and even more so going back together.
Old Mar 16, 2011 | 03:41 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Engine removal
with it being blown..... pull both
Old Mar 16, 2011 | 06:39 PM
Sparkytfl's Avatar
Re: Engine removal
I've put a rolling jack under the tail of the transmission to adjust its height and keep it from scraping as I pulled it out.
Yes trying to get the engine back in if you didnt pull the transmission was the hardest part for me last time. Took most of an hour trying to align them, then just suddenly got it right after my dad gave up helping me for the night and went inside.
Old Mar 17, 2011 | 09:36 AM
AutoRoc's Avatar
Transmission: 4L65E
Re: Engine removal
Jacking the rear of the car up makes life much easier
Old Mar 17, 2011 | 01:19 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Engine removal
I pulled mine seperatly, but looks like Ill be pulling them together when I pull out my 389. You think the added length of the t56 would cause an issue when pulling together?
Old Mar 20, 2011 | 12:04 AM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
Re: Engine removal
Hmm lift the rear
Old Mar 20, 2011 | 02:04 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Engine removal
Ive never done it with the trans attached, but in your case I think it's the best solution. If you're going to have to line everything up to get the TC to slide out of the trans anyway, I think you may as well just pull the trans out with it.
Old Mar 20, 2011 | 12:48 PM
Hiball8's Avatar
Re: Engine removal
I pulled them both together, raised the rear came out easy. Now i'll have to get it to an engine shop and see if it can be rebuilt, it broke the #7 rod in half and it was wedged into the bottom of the cylinder wall, that was fun trying to get it out.
Thanks for all the tips, helped pulling the engine and trans pretty smooth.
Old Mar 20, 2011 | 11:02 PM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
Re: Engine removal
Would it be easier to pull it out the top or to unbolt the k member and just roll it out? I just took the hood off mine, removed the radiator and fans.... Reason I'm asking is because the car has good paint. I don't know how much of a risk I'm taking pulling out the top.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
perZ
Aug 15, 2015 01:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
