Swapping 2.8 to 350 Transmission questions
Old Apr 1, 2011 | 05:47 PM
all80sG&F's Avatar
Car: 84 Montecarlo, 85 Camaro
Engine: 350, 350
Transmission: th350, 700r4
Axle/Gears: 3.73, 3.42
I have an 85 Camaro, it had a 2.8 and a t5 in it. I am trying to put a 350 and 700r4 in it. I have found a few 700r4s but I'm kinda leery of buying one because I'm not sure what the tail shaft housing I need looks like for sure. I've been told i need one the torque arm will mount to. So i was wondering if any one had a picture of the right tail shaft housing or maybe some advice to properly identify it. Any help will be greatly appreciated!!
Old Apr 1, 2011 | 06:05 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Swapping 2.8 to 350 Transmission questions
Only the F-bodies had the right tailhousing, so it's easy - if it came from an F-body, good, if not bad.
Old Apr 1, 2011 | 06:21 PM
all80sG&F's Avatar
Engine: 350, 350
That's the deal all the junk yards I've called and or visited have them pulled already and they don't know what they are out of. Iowa what can i say.
Old Apr 1, 2011 | 06:46 PM
Car: 1992 RS
Engine: Carbed 350
Found a pic - mount circled in red. Two long bolts go through the housing from driver side to pass side to hould the mount on. Red rubber is poly torque arm mount bushing.
Old Apr 1, 2011 | 06:52 PM
all80sG&F's Avatar
Engine: 350, 350
Awesome!! Much appreciated!!! just wasn't sure of the hole configuration i needed to look for
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
mizz0313
Aug 12, 2015 06:45 AM
milk
Aug 10, 2015 06:26 PM
