Carbed 350 swaps
Old Apr 5, 2011 | 11:28 AM
redzee28's Avatar
Car: 1985 z28
Carbed 350 swaps
Who has swapped carbed 350s in there camaro. I have an 85 z28 with 305 carbed. Looking to swap to a 350 but would like to know some things. Hows your gas mileage? Was the swap difficult and was it worth?
Old Apr 5, 2011 | 12:47 PM
Re: Carbed 350 swaps
Gas mileage - depends on the 305 and the 350. For otherwise equal motors, it will be about the same.
Difficult - that depends on who you are and what tools you have. Like, brain surgery probably isn't too "difficult" for a brain surgeon, but I doubt you'd want ME inside your skull with a knife. And, it's a real PITA to pull a motor with 4 guys, 2 4x4s, and a couple of chains, but it's been done; but a whole lot less "difficult" with a cherry picker. On the whole though, since it's not really a "swap", it's about as easy as it gets. If this one is "too hard" for someone, they need to take up a new hobby.
Worth - in the eye of the beholder. Personally, I would say, not; since it's basically the exact same effort to put in 50 more inches than that. Virtually the same work, twice the improvement. But that's just me.
Old Apr 6, 2011 | 12:26 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have a 4 bolt 355 carbed in mine.
Wiring is 12v to coil and starter 1 wire with a 10K series resistor for the tach. Temp and oil pressure converter to external mechanical gauges. MPG 9-13 I think a lot of that is the 3.73 rear end I also think I am running rich and often open all 4 barrels. I never drove the car stock with the L69 190hp HO engine but I have driven a camaro with a 305 and the mild 355 I have now blows it away. The fuel pump is a mechanical unit and I added a venting fuel cap.
theshackle
Mar 5, 2017 06:37 PM
bellez77
Sep 5, 2015 08:39 PM
theurge
Aug 21, 2015 12:46 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
