What oil goes into a rebuilt engine?
Old Apr 19, 2011 | 08:56 PM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
In other words, what engine specs determine the oil weight?
Does it depend on the valvetrain? Does it depend on the crank bearings? I have a 400 I want to rebuild. Still in the planning stages. The label on the oil cap won't matter any more, obviously. How is this determined properly?
Thanks!
Old Apr 19, 2011 | 09:28 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: What oil goes into a rebuilt engine?
Oil weight is determined by the temperature range the vehicle will be used in(summer only vs summer & winter), bearing clearances, and the intended use. Since I rebuilt my 350, I have been running standard 5w-30 non-synthetic oil with a ZDDP additive. I used the same stuff for the initial break-in as well. I haven't seen any signs of problems during oil changes. I only drive it during the spring/summer/fall and garage it over the winter. I wouldn't go much more than 10w-40 on any engine though. Especially if you're driving it in cold winters. I run that in my truck engine due to slightly lower oil pressures and it can take a little while for the oil pressure gauge to come up on the coldest winter mornings. I have another engine ready to be assembled for that truck so I'm not too worried about ruining the one that's in it.
toronto formula
Nov 10, 2015 06:17 AM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
