83 camaro with a 455 bb question
Old Apr 27, 2011 | 07:37 AM
ryans01z28's Avatar
i bought this 83 camaro with what is supposed to be a 455 oldsmobile big block & to determine that it is a 455 i measured across the intake & it come out to 14" accross & thats how me & another member determined it to be the 455. if this is correct i would like to know how to tell if this is a 455 "ROCKET" so if anyone know if they put a marking on the engine would you please let me know.
thanks in advance
Old Apr 27, 2011 | 09:27 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 83 camaro with a 455 bb question
All Oldsmobile V8's are "Rockets"... it's just marketing nonsense.
Old Apr 27, 2011 | 09:56 AM
ryans01z28's Avatar
are you 100% sure? i thought they might have made a base model 350 & a high output 350 "rocket" & same way for the 455's
Old Apr 27, 2011 | 10:08 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Here, this will help you....
http://www.442.com/oldsfaq/ofeng.htm
Old Apr 27, 2011 | 11:46 AM
ryans01z28's Avatar
i read through all of that info & it did confirm that i have a 455 engine. now is there any difference in a 455 & a 455 "ROCKET" or were they indeed called rockets just for hype?
Old Apr 27, 2011 | 11:52 AM
Originally Posted by ryans01z28
....now is there any difference in a 455 & a 455 "ROCKET" or were they indeed called rockets just for hype?
Apeiron was correct, and it was explained on that page that I linked for you....;
"The Rocket engine debuted in 1949. It was termed the Rocket 88 engine. This engine was big in NASCAR, in fact with the automatic (no manual trans available early on), the Rocket won 8 out of 10 races in 1950. This engine had a number of interesting features: overhead valvetrain, hydraulic lifters, oversquare bore-stroke ratio, forged crank with counterweights, aluminum pistons, full-floating wrist-pins, and a dual plane intake manifold.
In 1957 Olds released the J-2 Golden Rocket. This was a 371 inch engine with a six-pack (it only came with a six-pack) that put out 312 horses.
I guess that once Olds hooked onto the Rocket name in '49 and people associated it with Oldsmobile, they continued to use it for many years because of that association. You could say that any Olds built V-8 from 1949 up is a Rocket engine.
The word "Rocket" on the air cleaner decals was dropped in in the mid 1970's, maybe with the 1977 model year.
All Olds V-8 pushrod engines produced between 1949 and 1990 are considered "Rocket" engines. The "Rocket" designation comes from the general design of these engines, not the HP rating. Super 88's with Rocket V-8s won many races in 1949 and through the 1950's. The Rocket V-8 has been credited with starting the quest for more power and hot rodding
Old Apr 27, 2011 | 12:57 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
If it's like other GM engines, get the casting #s and look them up.
I've seen only 1 Olds 455 that was on a stand, that was about 10 yrs ago!
Old Apr 27, 2011 | 05:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Nothing wrong with an Olds engine. I've swapped a few of them. It was common to swap in an Olds engine when the 6.2 Diesel in your pickup truck died. Yanking out an 80's Caddy engine and installing an Olds engine is also a very easy swap.
Performance parts for the 455 will be a lot more expensive than BBC stuff because the demand isn't as high.
Old Apr 27, 2011 | 05:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm not sure I've ever seen one on a stand, but I saw one at the track last Friday in a Cutlass. Ran high-12's (at 5800' elevation). Original owner. Not sure how long she's been racing it, but certainly as long as I've been racing here.
Back when I first got started in bracket racing back in the late 70's, there was a racer with an Olds 455 in a '68 Camaro. Everybody thought he was nuts - right until he sent them packing.
Old Apr 28, 2011 | 05:23 PM
Car: '87 Camaro
My friend was going to put it in a '80something Cutlass, but things happen & he got rid of the car & kept the 455.
Heck, I'll go over & ask if he still has it & if I can get a few pics of it, along with a few tips on 400 vs 455 ID.
IIRC, Pontiac 400 or 455 had the 400 or 455 cast on the mid-block, between the freezeplugs. Or maybe it was a certain # to look for there that determined Cubic Inch of the block???
(edit)
Can't do it til Monday or Tuesday
Old Apr 29, 2011 | 09:09 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
thanks in advance
I'd love to see pictures!I'm not much on crossbreeding,but I LOVE me a 455 Olds,torques moves cars,and at 4.25 factory stroke,the 455 Olds delivers a metric asston of torque.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
