3.1L to 5.7L 350 questions
Car: 92 Camaro RS
Engine: 3.L tbi v6
Transmission: Manual
so i have a 92 camaro with a 3.1L tbi. its a manual.
i want more power, well alot more power.. so i want a 350. i know its not going to be easy or cheap but i was hpping i could get some answers from the guys who would know best.
i wanted to know the best place to find a 350 (crate or donor car) and what will give me most bang for my buck. i dont need a beast vortec or anything but just something better then a 305.
all comments will be greatly apreciacted. im only 18 but im already turning into a gearhead. id love any help. thanks
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
Re: 3.1L to 5.7L 350 questions
Well every junkyard Ive ever been to had dozens of 350s in them. Best bet to find a cheap 350 is to go to a junkyard and pull one. Ive also seen running 350s on craigslist for cheap also. A few things to consider though before getting into the swap. Ive already done the research on doing one in the past and it wont be easy.
-your going to have to change out the transmission
-engine mounts will have to be moved (PIA trust me)
-computer system will have to be swapped if you are going fuel injected.
-fuel pump is different
-possible emissions problems if your in a state that requires it especially since I see you have a 1992.
-Also if you swap transmissions make sure it has the correct tailshaft or you will have to get a diffrent crossmember.
Also if your looking at getting a carbed 350 it might not make all that much power well not a lot more (expect 200ish HP for a period carb engine). Your V6 should be making 160HP as is right now. Not sure if all the trouble is really worth the extra 50HP IMO.
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
