cloyes timing cover
Old May 5, 2011 | 05:27 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
cloyes timing cover
Does this cover work with a roller block? http://www.summitracing.com/parts/CLO-9-221/
Old May 5, 2011 | 05:35 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: cloyes timing cover
Being that it says "Timing Cover, 2-Piece, Adjustable Cam Button, Aluminum, Natural, Chevy, Non-Factory Roller Small Block, Each". I would say it's designed for old style due to the fact they give you a cam button.
I would say you would probably want this model:
http://www.summitracing.com/parts/CLO-9-225/
Was there a reason you were looking for another cover?
Old May 5, 2011 | 06:08 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Oh.. sorry bout that.. I didnt read all the way down. Well anyways I have the non-roller type cover with a roller block. Do you think that the center cover is inner-changeable? Maybe I could just order the right center cover from cloyes.
Old May 5, 2011 | 08:36 PM
Engine: 383 SBC
You could just call Summit Racing. They have a tech line they should be able to answer that question for you.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
