AHHHH STILL WONT START!
Car: 84 firebird
Engine: 355
Transmission: 700r4 stage 2 shift kit 2500 stall
Axle/Gears: 3.42 posi
ok so ive done a v6-v8 swap put a 350 in had it running no problem went to adjust the timing the distributor cap popped off and broke the rotor so i put a new rotor on(took the dizzy out to do this as it was raining) put it back in and nothing wasnt even getting a spark and all i smelt was gas so i ended up flooding the carb so i put a 750 q-jet on and tried again no spark now i am getting gas tho so i put all new e3 spark plugs in was getting a spark now (took the spark plug out and could see the spark ) tried starting it again and still wont fire im getting gas cuz i can smell it i put the first cylinder to TDC the dizzy dropped in facing number 1 im getting a spark and im getting gas it just will not start! any ideas would be great thanks!
Car: 1992 RS
Engine: Carbed 350
Re: AHHHH STILL WONT START!
Was dizzy dropped in when #1 was TDC on compression stroke or exhaust stroke?
Why in the world would anyone remove a distributor to stick a rotor button on it? I'm really lost on that concept. That's like removing the intake manifold to change the oil
Car: 84 firebird
Engine: 355
exhaust and i removed it while it was raining to bring it down stairs to rebuild it and at that time i discovered the rotor broken
Car: 1992 RS
Engine: Carbed 350
If dist dropped in on the exhaust stroke, then you are 180 degrees out - distributor has to be dropped in on compression stroke. Just move the dist cap wires all 180 degrees.
Misunderstood on the rotor button, sorry
Car: 84 firebird
Engine: 355
its all good lol and by turning it 180 do you mean if 1 and 8 spark plug wire are the very front two they would now be the back two where 6 and 5 are right and along with the others?
Car: 1992 RS
Engine: Carbed 350
Yes, kinda just swap them all directly across from one another.
Here's the extent of my artistic abilities:
Car: 84 firebird
Engine: 355
92camaroJoe
Aug 13, 2015 06:07 AM
