Turbo 400?
Old Jun 19, 2011 | 11:25 AM
jsanders's Avatar
Car: 1992 25 Anniversary Chevy Camaro RS
Engine: TBI 305sb
Transmission: 700R-4
Axle/Gears: Stock
Turbo 400?
I was wondering how bad/good of an idea a 400 sbc with 350 Vortec heads and the 350 TPI top end would react to lets say 8-10psi on 9.6:1CR?? I know when it comes to boosting an engine it's all about turning, but would this be a little much?
Old Jun 22, 2011 | 03:06 AM
tekkitan's Avatar
Car: 87 IROC-Z
Re: Turbo 400?
from what i've read from threads on here, a TPI will choke the 400sbc and not provide it with enough air
Old Jun 22, 2011 | 08:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Turbo 400?
too much compression unless you use race gas only. The heads and cam will choke that motor alot, so it will be a very low rpm type setup. 4000 rpm and no more.
Old Jun 22, 2011 | 08:41 AM
jsanders's Avatar
Engine: TBI 305sb
Axle/Gears: Stock
Re: Turbo 400?
Thanks for the answers, but I've decided to stick with my original plan of a carb setup.
Hotrodboba400
Dec 10, 2019 07:07 PM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
