LO5 to Vortec swap
Old Jul 15, 2011 | 05:18 PM
IrocZ'85's Avatar
Car: '85 IrocZ
LO5 to Vortec swap
Hey guys,
I've searched many boards and for the most part it seems vortec 350 are straight part swaps from other 87+ roller block 350s.
The reason I ask is because I blew up my LO5 350 and am looking for a new short block. I have non-vortec heads etc etc, and that will all be fine to swap over. I'm just wondering is there ANYTHING else on a 1997 vortec 350 that I should know about being different from my '92 gen1 LO5?
Does the timing chain and cover and balancer all swap over? I've read some people say that they cannot. I just plan to swap my cam, timing equipment, balancer, etc, and AFR 195 heads + HSR onto the vortec block. Just making sure it's pretty much a direct swap!
As clarification I'm not asking anything about vortec heads, just about the BLOCK itself.
thanks!
Old Jul 15, 2011 | 08:10 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: LO5 to Vortec swap
shouldnt have any issues with the block itself
Old Jul 15, 2011 | 10:03 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Why go for a short block? The Vortec heads are what makes it a good engine. Other than the heads it isn't much different than any other '87 up roller engines.
Old Jul 16, 2011 | 09:48 AM
IrocZ'85's Avatar
Car: '85 IrocZ
ok thanks! I'm going for any 350/355 short block i can find because I've already got AFR 195 heads to throw on it. so I don't need the vortec heads, i know they are pretty good tho
Old Jul 16, 2011 | 10:02 PM
squirrel's Avatar
Z85, I done this ,if I'm understanding the ? correctly, in a 92 PU with a long blk Vortec. All went fairly smooth, the timing chain cover did not swap from the 92 motor, been a while, last yr. and I'm old, seems, was a different bolt pattern. I just got an old sensor to plug the hole, works fine so far, my computer doesn't have, I think its a cam position sensor, sorry to be so vague, used 92 starter, water pump but was replaced at the time, dist. all but the intake, which as you know being the Vortec heads, I used the GMPP TBI intake, Would probably go carb intake if I done it again, alot cheaper. Hope this is some of the info you were lookin for, again, sorry for being so forgetful on this, It happens, can't see worth a crap anymore either, damn, I don't like gettin old, I use to think 51 was real old, not anymore, Pm, if I can help.
Old Jul 17, 2011 | 10:05 AM
IrocZ'85's Avatar
Car: '85 IrocZ
haha, thanks for the info squirrel! Getting old sucks indeed
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
z28addict8490
Sep 5, 2015 03:56 PM
earlpote
Aug 28, 2015 10:42 AM
jharrison5
Aug 19, 2015 05:53 PM
