Computer is Out
Computer is Out
I swapped in a 350 carbed Vette motor in place of the 305 TPI and took out the cpu. What do I need to do to keep th A/C working? I believe the cpu controlled at least the high pressure cut off.
Re: Computer is Out
No it didnt
The ECM controlled the relay ground leg and had a tee into the compressor control to bump up the idle when AC was engaged. The pressure switches were for the safety/function of the system. If the pressure was too high or too low they opened the compressor circuit disabling AC until pressure could be restored
Emulate an earlier carb setup
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
