Vortec head swap
Old Aug 26, 2011 | 12:52 AM
CamaroKidAndy's Avatar
Car: 1991 Camaro Z28
Engine: 305 TPI HO
Vortec head swap
Been reading alot about people putting the newer vortec heads on to the older engines. A buddy of mine and I were looking into this possibility but started wondering about alignment issues. We placeda head gasket for a set of vortec heads on an older sbc block, and they don't line up with the different holes. So how does one make this swap and deal with the effect of flow?
Old Aug 26, 2011 | 07:10 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Vortec head swap
vortec heads should fit up 100% to the engine block; if you're getting alignment issues, there's a problem somewhere. the only place vortec's differ on fit is at the intake side and require a vortec-specific manifold. everything else should fit without issue.
Old Aug 26, 2011 | 10:28 AM
Angelini's Avatar
I actually just took an old used '261 swirl port TBI head gasket to the bottom of my new 906 Vortecs to look at how they matched up, its an exact fit, and as 1ADan has said, if your having alignment issues then either you dont have the right gasket, or the heads arent Vortecs or something. I'll get a pic if I can of how the gaskets match up.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
