Flexplate for 307 & TH700
Old Sep 28, 2011 | 01:28 AM
aaronbauer's Avatar
i have a 86 camaro that used to have a 305 4bbl and i took it out and now have a 69-73 307 i need help finding which flywheel will fit my 700r4 trans. the flywheel off my original motor is 12.85 in and has a 2" hole for the crank. the 307 has a 14" diameter flywheel and like a 2.5" hole for the crank
Old Sep 28, 2011 | 01:31 AM
aaronbauer's Avatar
swap 305 to a 307 need flywheel help
Old Sep 28, 2011 | 06:57 AM
Re: swap 305 to a 307 need flywheel help
83-85 Camaro/Firebird V8
Be sure your heads have the accessory bolt holes, and that the block has the correct starter bolt hole
Old Sep 28, 2011 | 02:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should be able to use the 307 flexplate and starter with the TH700. If the flexplate doesn't have the proper holes to bolt up the torque converter, you should be able to find a replacement flexplate at a parts store that has both torque converter bolt patterns.
You can also use a flexplate from an '82-'85 f-body V8 automatic, but your 307 block may not be drilled for the f-body starter you'd have to use with it.
Old Sep 28, 2011 | 03:03 PM
five7kid's Avatar
I see now you posted your question twice. I have merged the threads.
84LsxZ28
May 17, 2020 02:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
roysatikas
Sep 7, 2015 08:08 PM
