LT1 swap questions
Old Sep 29, 2011 | 07:10 PM
jaben2's Avatar
LT1 swap questions
Please don't flame me too much. I have been searching around the site and read all sorts of threads to include the stickies. I was just wondering if there is a consolidated list of the minimum required items to do a LT1/4L60E swap into a 85 trans am.
1. LT1/4L60E/ I am using a 97 lt1 from a camaro,
2. Wiring harness, custom made or third gen 4th gen combo with 4th gen computer
3. Different K-member/modified one??? I read I don't need to change this.
4. Different Transmission crossmember???? Only for extra clearance, can modify stock.
5. Do I need to upgrade the radiator and fans???
What else is mandatory for the swap????
Any and all answers or suggestions appreciated.
Also what would be a decent torque convertor for this type of install. I will be going with Lloyd elliot setup/
http://elliottsportworks.com/home/?page_id=53
Old Sep 30, 2011 | 11:51 AM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
Re: LT1 swap questions
just sayin, if ya did a search for those things you would have found it.
SO... for the wiring, how much money you lookin to spend? you can build one yourself on the cheap, or buy a custom made one to your specs. i bought mine from eficonnection.
you can use a stock k member and you dont have to modify it if you arent putting A/C in it.
with the 4l60 you should be able to use the stock crossmember.
is your car originally a tpi? the rad should be fine, use dual fans, and if it isnt a tpi, replace the fuel pump to a tpi one at least.
Old Sep 30, 2011 | 12:51 PM
jaben2's Avatar
Those are pretty much the answers I had found. Just wanted verification is all.
Thanks for the response.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
