305 to 350 swap, flexplate issue
Car: 1988 Trans am
Engine: 358
So I tried started the 350 I swapped into my TA and the starter was slipping and eventually cracked. It looks like the teeth on the flexplate aren't set back far enough for the starter to catch properly. My question is it possible to install the flexplate on these cars the wrong way cause it looks as off there's a offset and that if I flipped it around the starter would catch better. Any help is appreciated.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 to 350 swap, flexplate issue
It's possible, but you'd notice when you tried to bolt up the torque converter.
Car: 1988 Trans am
Engine: 358
That's what I figured and I was fine when I bolted it up. Its killing me cause I was so close and nothing lol im thinking I just have to take the engine out and look at it again
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Is your current block the same RMS as your old one? (i.e. 1 pc)
Car: 1988 Trans am
Engine: 358
Yea its a one peice rear main, everything swapped over from the 305 so its pretty much identical except for the bore size. Its a 2nd gen block with tbi heads, '87 casting.
84z96L31vortec
Aug 20, 2017 12:16 AM
