Vid of swap and a couple of ?'s
Old Oct 8, 2011 | 09:33 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
http://www.youtube.com/watch?v=MPVV21C1n88
Not that I'm complaining, but I removed the EGR and smog pump when I put the 350 in and don't have an SES light. Is that good or bad?
Secondly, it still has the 305 chip in it. I have an AUJP and know I'll need it tuned due to heads, cam, etc. Is VATS on the chip or in the ECM? In other words, if I put the AUJP in, will it still start?
Sorry if these are dumb questions but I searched and couldn't find anything.
Old Oct 9, 2011 | 05:24 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Vid of swap and a couple of ?'s
you need a 350 chip and a 350 knock sensor. egr and smog pump missing wont hurt anything and wont even throw a code. are you saying you dont have a ses light as in the bulb isnt working at all? or just that its not lighting up indicating a problem? and VATS is programed into the chip IIRC.
Old Oct 9, 2011 | 08:51 PM
watajob's Avatar
Car: 92 T/A 'vert
AUJP is a 350 chip and I have a 350 KS. SES light functional just none right now. I just guessed it would throw a code if they were physically missing. My ? is still: will it start if I put in the AUJP w/o turning the VATS off via tuning?
Old Oct 12, 2011 | 11:51 AM
watajob's Avatar
Car: 92 T/A 'vert
Yes? No? Maybe?
Old Oct 12, 2011 | 11:53 AM
travis401's Avatar
Car: 91 Camaro RS
Not unless you have a vats bypass box that can feed the ecm the correct enable signal
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
jharrison5
Aug 19, 2015 05:53 PM
86Base
Aug 8, 2015 01:34 PM
