having a fuel issue in my fuel injection to carb swap
Old Oct 16, 2011 | 07:28 PM
Slayerx666's Avatar
i swapped in a carbed 350 into my camaro that had a tpi 305 in it. im having issues getting it to run. it has a mechanical fuel pump from an earlier 305 car. and i used the fuel injection return line from the tank as the new pick up. is that my problem? i know its a smaller line, butt i figured since it went down to the botom of the tank i could use it as a pickup. is that my problem? should i get a carburated fuel pick up, and run the regular feed line? is something stopping the fuel? whats my best option? id also like to keep the fuel gauge. any help appreciated!! thanks!
Old Oct 16, 2011 | 10:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: having a fuel issue in my fuel injection to carb swap
Do you know it goes to bottom of tank?
Old Oct 17, 2011 | 05:55 AM
Slayerx666's Avatar
Yes. When I pulled the assembly put it went just as low as the pump.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
midge54
Dec 27, 2019 04:14 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
