Belt Routing Trouble
Old Oct 17, 2011 | 11:10 AM
Desmodaeus's Avatar
Hey guys,
I have a 92 camaro with a carbed 350 in it. I took out the smog pump and followed the belt routing diagram here... https://www.thirdgen.org/serpentine This is a brand new build so I took the car out once and after driving it I realized it was overheating. I checked the thermostat, hoses, radiator, fluid, everything was good. Timing was off but has now been corrected. After looking into it more, I realized my water pump should be spinning counter-clockwise right? Then why do they show that belt routing for the smog pump delete? Doesn't that spin the water pump clockwise? I am very confused. I figured maybe I was overheating due to the pump spinning the wrong way, because on the routing diagram at the top of my fan shroud, it shows to wrap it around the opposite side of the water pump.
Old Oct 17, 2011 | 11:22 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Belt Routing Trouble
As long as it's the outside of the belt touching it, it will spin in the right direction.
Old Oct 17, 2011 | 11:26 AM
Desmodaeus's Avatar
Really? Hmm, well thanks for that information. That does however make things tricky then regarding the overheating issue. I figured it would have been the water pump direction.
F-body-fan
Jan 12, 2023 01:49 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
