Having hard time finding the right knock sensor
Old Nov 18, 2011 | 06:26 PM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
I have been having a hard time finding a 350'knock sensor for a 91 RS camaro... Can I use a tpi like this:
http://item.mobileweb.ebay.com/viewi...id=37250185787
Or what part number should I be looking up? I can't find anything, this is the only one I found.
Old Nov 20, 2011 | 05:58 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Having hard time finding the right knock sensor
If keeping TBI, use a B-body LO5 knock sensor/ECM/injectors
Old Nov 20, 2011 | 06:07 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Ok, so I'd be best off finding a truck or Buick/Oldsmobile/ etc with a 350, pulling that knock.... Only problem is I need to find one for a 91, right? Someone said my ECM is fine with the swap, actually a couple of people did, this not true?
Old Nov 20, 2011 | 06:19 PM
Pocket's Avatar
Car: 91 Trans Am
Try to avoid the truck LO5 stuff except for the injectors
The B-body stuff is essentially the same as your 3rd gen system, just packaged differently. Since it was available in the LO5, grab it and run it directly
The Truck is a completely different harness/PCM so minor sensors are not the same in all cases
FWIW, Id suggest buying new knock sensors. They're easy to damage
Old Nov 20, 2011 | 07:46 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Ok now where would I find a new knock sensor? I have been looking, I can't find anyone or anywhere that sells them.
Old Nov 20, 2011 | 08:07 PM
Pocket's Avatar
Car: 91 Trans Am
Any local parts store, dealer, rock auto, ebay, amazon even
Old Nov 20, 2011 | 08:15 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
Well I would have found it easier if I were to type in "91 caprice knock sensor", I was typing in "91 camaro knock sensor".... Ok, I found one...
db057
Aug 22, 2015 08:17 PM
mcquigg
Aug 13, 2015 02:26 PM
squiggy2
Aug 9, 2015 09:30 PM
gwade12
Aug 8, 2015 08:17 AM
apie2546
Aug 8, 2015 07:12 AM
