Duramax Thirdgen Swap
Old Jan 7, 2012 | 08:13 PM
  #151
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Duramax Thirdgen Swap
just picked up some wheels today 2011 corvette grand sport wheels 18X9.5 fronts and 19X12 rears got a steal on them but need to get the recoated and some curb rash smoothed out on two of them but for the price I couldnt pass up
Old Jan 7, 2012 | 08:25 PM
  #152
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
SAWEET!
Old Jan 7, 2012 | 08:28 PM
  #153
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
i actually like those
Old Jan 7, 2012 | 08:57 PM
  #154
lunati397's Avatar
I would like to get them rechromed or ill powdercoat them ill figure it out I like them cant wait to get a tire on and mounted and see these steam rollers out back
Old Jan 7, 2012 | 08:59 PM
  #155
Pillsbry10's Avatar
spacers?
Old Jan 7, 2012 | 09:01 PM
  #156
lunati397's Avatar
i have 2 inch fronts and a 4th gen rear might need a 1.5 rear also
Old Jan 7, 2012 | 09:07 PM
  #157
lunati397's Avatar
I looked and havent seen these on a thirdgen yet
Old Jan 8, 2012 | 05:51 PM
  #158
lunati397's Avatar
scored a set of coil overs today at a swap meet for 10 bucks I need to get different springs for the right spring rate but good deal
Old Jan 8, 2012 | 09:26 PM
  #159
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
i cant tell but the wheels you got, are they the same ones that are on the car behind the wheels?
Old Jan 8, 2012 | 09:29 PM
  #160
lunati397's Avatar
yeah the ones on the car are chrome now these were taken off because two have curb rash but i got the set for 400 so im not complaining and I do powdercoating so I can smooth it out and recoat the wheels
Old Jan 10, 2012 | 08:59 PM
  #161
abadv8's Avatar
Car: 1989 RS
Engine: LS1 - HP Tuners Enhanced 2Bar OS
Transmission: T56 - Pro 5.0
Axle/Gears: 9 Inch - 31 Spl Tru-Trac - 4.11
When you're ready to dial in the Durabux, you can get it done with some off the shelf tuners. And, no, I'm not talking Hyperchiptechdiablobanks... Look at PPE. I'm running their Xclerator in my 06 LBZ, and that thing is scary fast for an 8,000 lb truck. Of course, if you know what you're doing, and live by the pyro, you can run EFIlive. I think that'll be my next step as well. You'll find that you catch some sort of "more power" virus the Durabux, and suddenly 600 HP is not enough.
I am a little worried about the 4L80 idea though. I think you'll be glazing the clutches pretty quick. The 6.6 makes an incredible amount of torque at 2,500 RPM. You'll be over 800 lb*ft at that point if you get your tune dialed in. Idk what kind of clutch holding power you'll get out of the 4L80 at the RPM.
Speaking of low RPM's... what do you plan to run for a final drive? My truck is at 1,700 RPM, give or take at 70 MPH with the 6 speed Ally. If I run in 5th or 4th, my mileage goes to crap.
Anyways, the build looks awesome. Can't wait to see it done. Would love to see it at the track one day. Best of luck.
Old Jan 10, 2012 | 11:16 PM
  #162
lunati397's Avatar
im going to use efi live and distance tuning where I log then send off and get a tune with the V2 and I realize the hunger for more power but thats no different with gas or diesel you will always want more 600 range I can get away with a stock bottom ill start building a new block once this is all good and done for more
the 80 will be fine im going with a spragless 4th and red clutch same that would be used in a allison build and it will have a good convertor built for well over what I plan making
still need to figure out the final drive I might see how the 3.42s do and go from there but you have to remember your truck is 8k brick with a 32 to 33 inch tire ill have a 27.5 tire so thats all up in the air now still I need to get farther along to know what will work best but the final rearend will be a fab9
Old Jan 11, 2012 | 08:36 AM
  #163
abadv8's Avatar
Car: 1989 RS
I guess I was concerned about developing enough line pressure at low RPM to prevent the clutches from slipping and chattering. That would be the biggest difference between the behavior of the 4L80 and the Ally.
I found a breakdown of same year transmission ratios…
2006 4L80/4L85 Four-speed Auto. ( MT1/MN8 ), with LQ4 6.0L Vortec Gas V8
Axle Ratio: 4.10
Trans. ratios: -- Total Ratio ... (max. torque @ rear axle)
First: 2.48 ------ 10.168 ........ (3,660)
Second: 1.48 ---- 6.068 ........ (2,184)
Third: 1.00 ------ 4.100 ........ (1,476)
Fourth: 0.75 ----- 3.075 ........ (1,107)
2007 6L90 Six-Speed Auto. ( MYD ), with LY6 6.0L Vortec Gas V8
Axle Ratio: 3.73
First: 4.03 ------ 15.032 ........ (5,607)
Second: 2.36 ---- 8.803 ........ (3,283)
Third: 1.53 ------ 5.707 ........ (2,129)
Fourth: 1.15 ----- 4.290 ........ (1,600)
Fifth: 0.85 ---- -- 3.171 ........ (1,183)
Sixth: 0.67 ------ 2.499 ......... (..932)
2006 Allison 1000 Six-speed (MW7), with L18 8.1L Vortec Gas V8
Axle Ratio: 3.73
First: 3.10 ------ 11.563 ........ (5,203)
Second: 1.81 ---- 6.751 ........ (3,038)
Third: 1.41 ------ 5.259 ........ (2,367)
Fourth: 1.00 ----- 3.730 ........ (1,679)
Fifth: 0.71 ---- -- 2.648 ........ (1,192)
Sixth: 0.61 ------ 2.275 ........ (1,024)
2006 Allison 1000 Six-speed ( MW7 ), with LBZ 6.6L Duramax diesel
Axle Ratio: 3.73
First: 3.10 ------ 11.563 ........ (7,516)
Second: 1.81 ---- 6.751 ........ (4,388)
Third: 1.41 ------ 5.259 ........ (3,419)
Fourth: 1.00 ----- 3.730 ........ (2,425)
Fifth: 0.71 ---- -- 2.648 ........ (1,721)
Sixth: 0.61 ------ 2.275 ........ (1,479)
One thing that I would like to point out is that in 2006 the OE tire size on these truck was 245/75R16E. That’s a 30.5” tire. FWIW.
Overall, it seems that you will be leaving nothing to chance.
Old Jan 11, 2012 | 11:35 AM
  #164
lunati397's Avatar
you are right about there being enough line pressure because it wont be spinning high enough but I can assure myself with ajusting the pressure and the 80s do produce low line pressure and have been behind the duramax from the factory in all the 6.6 dmax conversion vans stock to stock
what I will have to see is how it feels rather than rely on the numbers is the final drive I want to have the best well rounded car tq will make up for gearing but I dont want to be at a point where I trap at 132 and i redline at 132 and my top speed is 132 I go alot by feel more than numbers. like one motor I had was alot less powerful numbers wise than guys I raced but I would destroy them some of it was driving, weight, gears, hell the enviroment that I raced in there are alot of things that paper and numbers will not give me
Old Jan 12, 2012 | 06:42 AM
  #165
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
**** with that torque you could get away with 2:73s or some 3:08s.
wanna sell those for what you got those rims for? i wouldnt mind taking those off your hands as i do powder coating aswell and it wouldnt be nothing for me to recoat them..
Old Jan 12, 2012 | 03:56 PM
  #166
lunati397's Avatar
lol they were a deal and they are rare being they were only on a few models so I might be holding on to them
they were gunmetal then painted and poorly painted too because where the curb rash is I can peel it off in flakes
Re coat them or polish them and sell for 4 times what I paid
Old Jan 13, 2012 | 01:45 PM
  #167
87 "BlackBeast"'s Avatar
Car: 1987 Camaro Iroc-Z
Engine: 305ci TPI
Transmission: 4 Speed 700R4 (stock)
hows the swap comin? havent updated in awhile jus curious
Old Jan 14, 2012 | 07:37 PM
  #168
lunati397's Avatar
Im in san antonio for the next month for a class but will get on it when I get back in the time being I will be buying parts
Old Jan 18, 2012 | 10:07 AM
  #169
85z28kid's Avatar
Car: 85 iroc-z28
I'm first inline if you decide to get rid of them lol.
Old Jan 25, 2012 | 10:30 AM
  #170
lunati397's Avatar
Im going to use them just have to mini tub the rear and the tires are 345 35 r 19 DRs that are 404 a piece but its going to look mean
Now for some opinions I have a white car and I like chrome or polished aluminum but what color should I coat the rims if I decide to powdercoat instead of getting them chromes or polishing them
I am painting the car bright white with a blue pearl and the black parts will have a red pearl and the RS will be the R will look like a ice cube and the S will look like a the cube is on fire the motor will be accented with blue powdercoating either cobalt or a translucent over chrome powder
Old Feb 6, 2012 | 10:51 AM
  #171
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Axle/Gears: 3.42 Locker
You took my dreams and are putting them into reality!!! I wanted to do this after college. Your mpg are going to be ridiculous!!! Hotrod mag published a 94 mustang with a duramax that runs 9's and hits 38 mpg. He also ran over two hundred in the standing mile. You chose an awesome engine to swap into a thirdgen. Diesels sound awesome and perform great. This world needs more of them. Thanks for taking on this project!!!
Old Feb 8, 2012 | 11:39 PM
  #172
86bumbleb's Avatar
Car: 1997 Toyota Chaser JZX100
Engine: 1JZGTE VVTI
Transmission: 4spd auto
subscribed
Old Feb 8, 2012 | 11:53 PM
  #173
lunati397's Avatar
I get back home next week so there will be updates again I have some other projects that will have priority but ill be getting what I can done
Test fit new wheels build the K member and get the motor and trans in and start working wireing harness
Old Feb 11, 2012 | 09:02 PM
  #174
Cray z28's Avatar
Car: 1985 Z28
Engine: 8.3 ltre viper
Transmission: Tremec T6060
I just bought 20x12 rears and 19x10 fronts.They are almost the same as the ones you have. They are for a 2011 corvette zr1
Old Feb 11, 2012 | 09:39 PM
  #175
lunati397's Avatar
the ones i got were off a 2011 grand sport those are one inch bigger keep up I will start fitting them soon I have a 4th gen rear already im thinking roll the fenders 1 inch spacer and mini tub and the nitto NT05R Drag radials 345/35/R19 rears and the 555r fronts around 275 wide
put down fresh asfault because the steam rollers will be coming
Old Feb 12, 2012 | 06:06 PM
  #176
Cray z28's Avatar
Car: 1985 Z28
Yeah my rims are 20x12 19x10. The rears are 335-25-20....285-35-19. I am going to keep the stock body lines and tub it. Nice build. You are flying through it. Great job.
Old Feb 15, 2012 | 03:50 PM
  #177
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
sub'd YOU CAN DO IT, we should have a thread like the COTM thread for the fastest and most powerful cars on the board
Old Feb 15, 2012 | 04:36 PM
  #178
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I prefer Chevy in a Chevy but I'm up for this build. The curiosity factor is high and I want to see this through to completion. Keep up the good work.
Old Feb 15, 2012 | 04:59 PM
  #179
Richboll's Avatar
Engine: 305 TBI
I'd go with cobalt blue on the wheels and maybe some colbalt blue highlights inside and on the car. This maintains the continuity of your engine theme.
Old Feb 15, 2012 | 08:41 PM
  #180
Cray z28's Avatar
Car: 1985 Z28
Uhhhhhhhhh Richboll, Duramax's do go in chevy's!
Old Feb 15, 2012 | 10:30 PM
  #181
Richboll's Avatar
Engine: 305 TBI
When you throw in the terms of Izuzu and diesel, they've never been in any Chevy I've ever owned and I've owned a lot of them from back in the day when anything from a small block fit on almost any other small block and ditto for the big blocks. That being said, I do find this an interesting swap and admire the efforts that are being done to make it work. And being an old drag racer, I'm anxious to see the end result. Maybe I'll be a convert.
Old Feb 16, 2012 | 12:57 PM
  #182
lunati397's Avatar
anything duramax NOW as in the past 2 years is 90 % GM they have been redesigning the duramax to exclude izuzu from the rights because toyota now owns a part of izuzu so to keep them from getting it they had to make it all GM
look up the 4.5 duramax that they were supposed to make thats an awsome motor same size and weight as a 350 and it got 30 plus mpg in a 1500 also made same power as a 6.6
Old Feb 16, 2012 | 09:16 PM
  #183
Seafarer12's Avatar
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
I am not much of an electronic diesel kind of guy but this should be interesting.
Old Feb 16, 2012 | 09:41 PM
  #184
Richboll's Avatar
Engine: 305 TBI
OK so we are all on the same page with this. Let's see how it goes. Like I said before, some of us may become converts.
Old Feb 16, 2012 | 09:48 PM
  #185
Seafarer12's Avatar
I was mainly subscribing to the thread more than anything. Don't get me wrong I have wanted to do a 6.5 TD for a few years.
Old Feb 18, 2012 | 03:23 PM
  #186
SweetRevelation's Avatar
Car: '89 GTA
don't be so ignorant.
Old Feb 18, 2012 | 04:09 PM
  #187
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
From WIki,
The Duramax is a General Motors diesel engine family for light- and medium duty trucks, designed by Isuzu. The 6.6-liter Duramax is produced by DMAX, a joint venture between GM and Isuzu in Moraine, Ohio. This engine was initially installed in 2001 model year Chevy and GMC trucks and has been an option since then in pickups, vans, and medium-duty trucks. In 2006, production at Moraine was reportedly limited to approximately 200,000 engines per year.[1] On May 9, 2007, DMAX announced the production of the 1,000,000th Duramax V-8 diesel at its Moraine facility.[1]
Old Feb 18, 2012 | 05:48 PM
  #188
lunati397's Avatar
well back to on topic I am back in town now but have another project that is priority over mine
Taking a V6 Auto 99 Firebird and making it a LS6 6 Speed
powdercoated and put the motor together yesterday
Old Feb 18, 2012 | 05:51 PM
  #189
lunati397's Avatar
got some key peices in for mine too got the remote oil filter kit and the tailshaft for the trans and I ordered the DOM to make the K Member so hopefully I will get the motor to fit and mount up in the car soon
but I am doing all the same stuff with the firebird
Old Feb 18, 2012 | 05:53 PM
  #190
85z28kid's Avatar
Car: 85 iroc-z28
That motor looks really good now! Hope to see that motor in soon. Do I hear making a few k members and selling them?
Old Feb 18, 2012 | 07:07 PM
  #191
lunati397's Avatar
thats the plan after I get this one designed and good and tested then maybe a production I am making sure to make very good jigs for easy reproduction
Old Feb 18, 2012 | 07:37 PM
  #192
Seafarer12's Avatar
Never owned a Diesel Chevy LUV?
Old Feb 18, 2012 | 11:38 PM
  #193
Richboll's Avatar
Engine: 305 TBI
Nope, never owned any kind of diesel. I joined this forum because I thought this was about cars...Sorry about my ignorance 'SweetRevelation" but the closest I've even gotten to owning a truck is my 82 El camino.
I thought this might be an interesting thread to follow but personal attacks? because of something associated with Izuzu? count me out!
Old Feb 19, 2012 | 12:57 AM
  #194
kmcn47's Avatar
Transmission: 5spd
i think cobalt blue wheels would look bad on any color car
Old Feb 19, 2012 | 03:39 AM
  #195
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
maybe someone can tell me what an Isuzu Hombre or the I-series pickup was (lol sorry had to throw that out there.)
Old Feb 19, 2012 | 04:46 AM
  #196
kmcn47's Avatar
Transmission: 5spd
i'd love actual build updates, rather then arguing just me though
Old Feb 19, 2012 | 10:07 AM
  #197
Seafarer12's Avatar
Richboll, No insult intended. I am sorry if you took offence. I wont joke around with you anymore.
Old Feb 19, 2012 | 11:26 AM
  #198
lunati397's Avatar
working on it
Old Feb 20, 2012 | 12:41 PM
  #199
Cray z28's Avatar
Car: 1985 Z28
Hey richboll don't leave. This site is about cars, badass cars, and creative minds that create these beauties from a twisted vision in their head. No insults just jabbing back and forth. Keep up the great work Lunati. I am close to mocking up the k member for my build as well.
Old Feb 20, 2012 | 12:43 PM
  #200
lunati397's Avatar
I spent all day yesterday with the plasma cutter and cut off torch making small manageable pieces of what was left of the donor truck I need the space back wife was tired of it and a long bed crew cab 2500hd is a big mother trucker
got it down to the frame and thats gone today
