Final decision gm5.7 to t5 trans
Old Nov 29, 2011 | 01:55 AM
da84Berlinetta's Avatar
Car: Trans Am
Transmission: t5
Axle/Gears: 3:73 borg
I have heard so many bad things in regards to a t5 stock trans holding up to anything bigger than the 305. But on the other hand have read alot of people some whom rebuilt there trans and blew it in a year some whom are on their 8th and 9th year driving their t5 and 350 setup. I guess its how you drive for anyone who says a t5 will not hold up you mean it wont hold to grinding 2nd gear every time and trying to powershift right? Will definitely be driveable. I plan to push my car, chirp gears here or there no racing but a daily driver. The engine will be a 92 5.7 carb aluminum heads intake carb headers exhuast. Any have faith in the t5 low mileage good condish or is everyone going to say to spend 1500$ on the t56 and start hacking away modifying my third gen to put in.(ps i have the engine 5.7 and an 86 trans am blown motor good T5 trans)
Old Nov 29, 2011 | 03:59 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Final decision gm5.7 to t5 trans
the t5 will hold up very well behind a 350, if you drive it under normal driving conditions. the problem with that is the people who swap in a 350 do it because they dont want "normal driving conditions"
that tells me youre one of those people. you can run the t5 for a bit, but once you start pushing it, its days are numbered.
Old Nov 30, 2011 | 07:16 PM
Car: Trans Am
Transmission: t5
Thanks man ya if I can get a good summer out of it ill be happy
ZZ3Astro
Aug 13, 2019 12:57 AM
Antips16
Oct 30, 2015 06:42 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
roysatikas
Sep 22, 2015 08:15 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
