Tbi to tpi Maf
Old Dec 19, 2011 | 11:08 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Tbi to tpi Maf
Hey everyone I got a 87 305 tbi truck engine I'm looking to swap into my gf 86 trans am I got a 88 tpi intake, runners, fuel rail, pluemn, an throttle body will all of this bolt directly up to the 87 tbi engine or do I have to change to the tbi harness inorder to use it
Old Dec 20, 2011 | 12:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Tbi to tpi Maf
The TPI hardware will bolt to the '87 TBI engine.
You can repin a TBI harness, but it makes a lot more sense to buy a TPI harness. Usually available in the classifieds on this Board.
Old Dec 20, 2011 | 09:36 AM
Engine: LR4 4.8
Re: Tbi to tpi Maf
The 86 trans am already has a tpi 305 in it. It spun a bearing an instead of rebuilding it I'm just putting another 305 in it I already have te tpi harness in the car
Old Dec 20, 2011 | 04:06 PM
five7kid's Avatar
Okay, I see what you were saying now. The TBI harness stuff was confusing, since you shouldn't need anything of the TBI system itself. I also assumed the '86 didn't currently have TPI.
Yes, the '86 accessories will bolt to the truck longblock, and the '88 TPI base will bolt to the '87 truck heads. However, I'd be inclined to have the '86 heads redone and put them on the '87 shortblock. Better flowing heads, and your existing TPI base will bolt to them. The only advantage the '87 heads have are the centerbolt valve covers.
Old Dec 20, 2011 | 07:09 PM
Engine: LR4 4.8
Re: Tbi to tpi Maf
Does the oil pan need to be changed the angle looks alot different it has like a slight angle going down into the oil well pick up unlike the passenger car sbc oil pan that is flat an then has the bottom well
Old Dec 20, 2011 | 08:36 PM
five7kid's Avatar
You may need to change the oil pan.
89GTAOz
May 16, 2020 09:31 AM
NBrehm
Aug 25, 2015 11:49 PM
Bert87
Aug 23, 2015 03:50 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
