How to hook up my gauges?
I bought my car as a roller. It had a 305 tpi motor, and the harness was hacked out, all the wires cut near the firewall. It there a way to hook up maybe some of my gauges? Water temp, oil pressure? Speedo? Or am I better off using autometer stuff?
Transmission: 4L80E/4L80E
Any idea why they cut the harness?
The factory routed the gauge wiring through the firewall in the driver side corner. If there is enough of the wire length left, you can splice into them. Otherwise, you can probably find an intact used harness to replace it.
Re: How to hook up my gauges?
There's enough wire there to splice into. Any idea which ones are which? Kid I got there car from jumped into this thinking he was making some
Race car with less knowledge than I have, started cutting and gutting, realized he was in over his head, and sold the car.
Car: 1986 Pontiac Trans Am
Engine: 355 SBC
Axle/Gears: 2.77
Lots of diagrams on this site. I used all of these when removing tpi, and all my gauges still work so they must be good!
Ben
Ben Thread
gta892000
Sep 16, 2015 12:37 AM
