305 tpi to 383 carb
Old Jan 8, 2012 | 05:28 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
Axle/Gears: 10 bolt posi 3.08 gears
305 tpi to 383 carb
hows it goin im gonna be doing a swap in my 87 iroc im goin from the stock 305 to a 383 the car is a tpi setup but im going carb ive never built an engine before and need some help with some of the parts going into it heres what im thinking
rhs pro torker vortec heads
eagle 383 rotating assembly with flat top pistons
comp cams mother thumper cam not sure of the specs or what type of cam yet any help is appreciated
holley street avenger carb
weiand stealth air strike high rise intake and a carb spacer
the car is for street maybe if i work up the courage hit the strip just to see what it will run
comp 1.6 roller rockers
hooker super comp headers
ive seen similar setups make around 425-450+hp
Old Jan 8, 2012 | 08:08 PM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Re: 305 tpi to 383 carb
if you have never built an engine before, maybe you should take that 305, disassemble it, a rebuild it to gain experience, that way you won't have any problems with the 383 that could cost you a huge amount of money in damage.
Old Jan 9, 2012 | 03:00 AM
1gary's Avatar
Hint-hint,when you buy the bottom of the barrel parts(Eagle),you get the bottom of the barrel parts.
Old Jan 9, 2012 | 05:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Do a Google search on 383 builds.
Plenty of online info out there on what parts to use to make what HP
Only limit is your budget
Old Jan 9, 2012 | 04:23 PM
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Old Jan 11, 2012 | 10:43 AM
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
Yea... I was going to build a 383 for my car, but decided against it when a friend of mine told me he had a 350 pushing 400HP out of his stock car(race). 400HP is around the mark I was looking for so it worked out well. To build a good 383 you're going to be around the 10 Grand mark by the time you are done upgrading all the stuff you have to.
Jumping from lets say 195(maxish) HP on your 305 to 400+HP 383 You're going to be replacing(rebuilding) your Transmission, and rear end. Not to mention adding some traction bars and or stabilizer bars. Depending on your transmission it'll be expensive. if you're sporting a 700r4 plan to spend about $1500-$3000 on beefing it up enough to hold the HP.
Old Jan 11, 2012 | 02:58 PM
87iz28383's Avatar
Car: 87 Iroc
Engine: 305 for now
ive been reading alot on the 383 im pretty sure i could do it just worried cuz lack of experience and the money im gonna be puttin in the car i plan on having most of the work done by the machine shop
i got a 350 turbo trans off a friend of mine plan on having a shop rebuild it as well and the 5/16 bolt in the carrier broke off and the pin slid back into the pinion gear so i have to get a new rearend anyway planned on putting some new shocks, springs and other suspension under while its apart
my girlfriends dad does paint and body so probably gonna have him fix the rust add subfame connectors and paint it after all the drivetrain is ready
for colors i was thinking a darker blue, gun metal silver or black what do u guys think
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
