5.0L to 5.7 1500 engine
Old Jan 25, 2012 | 10:32 AM
mightydunk's Avatar
Car: 1990 Iroc-z Camaro
Engine: 5.7L
Transmission: Automatic
So my iroc camaro is a 5.0 liter so I decided I want to swap it out for a 350 and got an engine out of a chevy 1500 1993 the engine came from I think its called rhinoengines but it has aless than 100 miles on it im gonna carberate it as well so any hints or tips/suggestions anyone can throw at me and what would be a good carb for high performance right now the engine is stock the camaro still needs the 5.0 pulled from it will the stock auto tranny be good?
Old Jan 25, 2012 | 10:49 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: 5.0L to 5.7 1500 engine
The trans will be fine..the 93 5.7 from a 1500 has 210HP
The 90 5.0 TPI had 220
Old Jan 25, 2012 | 10:52 AM
88gta3508's Avatar
Engine: 231 / 383
Why go backwards and loose serious mileage
Install a HSR or similar
Old Jan 25, 2012 | 11:08 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
+1 to this.
Nothing wrong with using the truck motor, but you're going to lose power unless you switch out the heads/cam. You also lose the roller cam you had and you're stuck with a flat tappet cam unless you spend a decent amount of money converting it over.
Old Jan 25, 2012 | 01:58 PM
mightydunk's Avatar
Engine: 5.7L
I was worried more about the torque with the rear end rather than the horsepower and the 5.0 had 260k miles on it so I think a 10hp loss is worth the time I get to keep a new engine
BRoss99
Aug 10, 2025 05:08 PM
toronto formula
Nov 10, 2015 06:17 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
