403 olds into 86 Firebird
Old Mar 28, 2012 | 01:08 AM
Clipperet's Avatar
I bought a 403 infront of a 350 in a 64 Cutlass. Went back to the 330 in it and found an 86 Firebird without motor or tranny. Now the fun begins.
403 has Performer intake and cam. I am planning on a 750 edelbrock carb. Have a Spohn torque arm for it and hope to put 3.43(?) posi in the rear. I have the shaker breather and scoop to mod in as well. I hope to have some fun with this car. Lots of info on this site so I have no questions for now, just open to comments.
Old Mar 28, 2012 | 04:17 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 403 olds into 86 Firebird
IIRC, those are "windowed blocks". Cranks like to go "boom" in thise.
Old Mar 28, 2012 | 05:30 AM
82tarecaro's Avatar
Here is a Hotrod article on how to build up a 403. They installed a girdle to strengthen the windowed main webs.
http://www.popularhotrodding.com/eng...e/viewall.html
Old Mar 28, 2012 | 06:12 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Subscribed.
I put an Olds 350 in an 87 Formula once. I loved it. I suggest using second gen Firebird 403 motor mounts setup. You can buy them new from places like year one and classic industries.
I used stock Olds big block manifolds, MAYBE you can mod some 2nd gen headers, I don't remember.
Are you going auto or stick transmission?
A 3.42 rear axle is easy to find. Most, if not all, V6 cars came with them. You can use a 98-02 4th gen Zexel Torsen posi unit and rear discs to spruce it up. Heck, if your car was a V6 car from the factory you might already have 3.42's in it.
Please take lots of pictures. I didn't and I really regret it now.
Good luck!
Old Mar 28, 2012 | 08:41 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Good luck!
Just keep in mind that the Zexel Torsen unit is designed for 28 spline axles, and the 86s still had 26 spline. To use that Zexel you'll need some new axles, or grab some from a late model 3rdg gen that somebody is parting out.
Old Mar 28, 2012 | 09:24 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Yep, I always forget about that hahahhahha. Its been a while since I had an older 3rd gen. All of my junk is 28 spline.
I would go ahead and just buy a set of high strength replacement axle shafts from Summit. They're cheap and work well with the Zexel Torsen unit.
Thanks for the catch, Jim85IROC!
Old Mar 28, 2012 | 12:13 PM
Jim85IROC's Avatar
I took a similar route when I upgraded my IROC diff. I picked up some Moser 28 spline shafts and an SLP take-out Zexel posi back in the early 2000s when they were reselling the Zexels that they pulled from the SS/Firehawk cars for $99.
Old Mar 28, 2012 | 12:18 PM
82tarecaro's Avatar
I did that way back in the early 90's. At the time I had Moser custom cut a set of 28 spline axles and I bought an Auburn carrier for the 7.625 inch ring gear.
Old Mar 28, 2012 | 12:24 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
...I suggest using second gen Firebird 403 motor mounts setup. You can buy them new from places like year one and classic industries...
Classic Industries part no. C269503, about 145 bucks.
It comes with the shells that bolt to the block for a Pontiac or Olds V8, and a set of flat plates that let you adjust the position (forward or back) of the motor mounts on the block.
Old Apr 18, 2014 | 05:20 AM
Clipperet's Avatar
Been a long time since this started but the 86 is gone to the Exhaust shop... finally! The project has grown some. Unfortunately (or maybe fortunately for my wife) I didn't have the time to do this for myself. Fast Frankie in Cole Camp, Mo. has done all the heavy lifting on this. My contribution has been to add to the work scope every few months.
I'll post the mods for the engine swap in about a month from now. The little things were the time killers.
It now boasts an 02 TA rear end with 4.10 gears.
I drove it! Felt good but since there was no exhaust system, I didn't really feel like pressing the noise ordinance issue.
Headliner finally disintegrated from sitting outside so long so I guess I'll do some interior work after all. Planned on just driving it as is. Oh well. All that will continue on the rides thread.
Last edited by Clipperet; Apr 18, 2014 at 05:24 AM. Reason: realized most of the post was not about swapping
colton_carlson
Mar 8, 2019 12:21 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
justin57
Aug 20, 2015 07:05 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
Greg '85 T/A
Aug 14, 2015 01:40 PM
