355 build/install
Old Apr 18, 2012 | 10:19 AM
  #51
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
Re: 355 build/install
the tbi is really going to hurt your performance, since you are using the tbi the numbers i said before are very realistic.
and once you know your gasket thickness and deck clearance you can use that compression calculator in the link for your pistons
Old Apr 18, 2012 | 10:30 AM
  #52
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Originally Posted by 92firebird 305
So i have some questions i have a 350 bord .30 over with a scat crank polished lt1 cam in it 350 tbi heads with new valve springs ported and polish on the heads how much power am i looking at im hoping for over 300 to the tires and 320 tq
Beyond displacement and compression (and even those are indirect), the only thing that makes power is the cam, the heads, and the intake. I will assume a perfect world intake. You're using a factory sized roller cam from the early 90s, and fatory log truck heads from the late 80s. LT1 cam is good for 285hp in an LT1, and the 350TBI heads are good for maybe 210hp? Since that is the case, why would you expect more than 300hp anywhere in the drivetrain? Is it because the 193 heads are ported?
Originally Posted by JPrevost
All 87-95 truck and car TBI v8 engines got swirl port heads. Same with the Sy/Ty turbo v6 (LB4 heads). These heads are TERRIBLE for flow, the intake port size is huge at 185cc but they flow less than any other production chevy head! The only good thing about these heads is that the combustion chamber isn't AS pathetic. I can think of at least 4 other heads that have worse chambers but that doesn't make up for the fact that your cylinders are barely filling with air and fuel!
This post should be a sticky where people ONLY post information regarding these heads. No posts about "they aren't that bad" because face it, they are.
The LB4 heads were tested to flow only 165/119 (in/ex) @ .500 lift. To put that into perspective I've attached a graph showing you a couple other heads.
Graph has been updated to show that with porting the heads will flow something more respectable. The intake still falls way short but the exhaust is where the sbc has always needed work. Dyno Don has done his homework and made these heads work rather well. He polished the exhaust port and touched up the intake, look at the flow and his 35+hp gain. Good job Don.
If you are LUCKY they will flow as well as stock L98 heads which MIIIIGHT get you to the 250 range with a good dual plane intake like a Performer RPM.
Also, be ready to run race gas with dome top pistons and 64cc heads. Pump gas isnt gonna cut it with that kind of compression level and that tiny cam.
Old Apr 18, 2012 | 01:44 PM
  #53
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
ya i would think so this is my first time having a motor built so im trying to learn if i could get my hands on some vortecs or 113 heads that would make a big difference i would think
Old Apr 21, 2012 | 08:14 PM
  #54
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
took the car on its maiden voyage today, the fan keeps the car where i want it at temp wise. the 750 is way too big, i put the pedal to the floor and the wideband hits full rich and the car bogs and then takes off. so i switched it out for a holley 600 laying around. it seemed to run a lot better with that carb. this time dad was driving the car, he put the pedal to the floor, and it stuck, turned the car off while going 60 or so, the wheel locked and headed right for the woods, turned the car back on, it took off again and we finally got it stopped. im sooo glad we did not crash the car lol
so its time for a new carb, it sticks for no reason, even with doing it by hand. that is something i wont risk it again. this time it will be a holley 650 dp.
Old Apr 22, 2012 | 04:30 PM
  #55
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
i just ordered the 4777c carb and fuel line for it, ill have it by tuesday. this one should do much better
Old Apr 22, 2012 | 06:01 PM
  #56
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
what rearend are you running?? is it 10 bolt, 12 bolt? 9 inch? I am in the mid stages of building my 355/700r4 combo. my 700r4 is stock though. also 10 bolt open diff for now. I'm quite nervous of my rearend though. 3.23 gears in it. I plan on babying the car this summer and start horsing around with it towards fall for a stress test. if it lasts I will probably leave it as it is, but still thinking of upgrading rearend with 3.73's and some stuff to strengthen the rear end up.
Old Apr 22, 2012 | 06:13 PM
  #57
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
it is stock 10 bolt rear and stock 28 spline axles, auburn gear posi and 4.10s. it has held up fine with a 406 in front of it.
if you plan to run 26 inch tires 3.73 or if you run 28 inch tires 4.10s, my personal opinion but i have had great success with the 4.10s and 28s.
Old Apr 22, 2012 | 06:42 PM
  #58
Car: 1986 Camaro
ahh.. ok.. so my tires = 295/50R15 hows that convert to your inches?
Old Apr 22, 2012 | 10:15 PM
  #59
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Man you really powered through this, my 350 (soon to be 383) block will be back from the machine shop by the end of the week, I'm hoping to move this fast too
Old Apr 23, 2012 | 06:20 AM
  #60
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
hey man I'm glad that you your dad and your car are alright. that is alot of hard work I would hate to see it wrecked. I'm glad you could save it! Get it running perfect and please post a vid we would love to see it!
Old Apr 23, 2012 | 08:13 AM
  #61
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
your tire is a 26 inch tire, converts to 26.5, so i would go with the 3.73s
thanks guys, i had a lot of hard work and many hours in it.
the carb was not worth trying to figure out, all it would take is it to stick again and it could be my car and or my life
Old Apr 29, 2012 | 07:49 PM
  #62
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
havent updated in a while but i have decided to do a tranny swap now. either a 350 or 400 with a brake.
Old May 19, 2012 | 07:07 PM
  #63
GreggymacZ28's Avatar
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Any updates? We have similar setups with the same goal in 1/4 time!
Old May 19, 2012 | 09:14 PM
  #64
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
still working on it, i started a new job and i have the money for a new trans, i bought a set of founders lcarbs and controls arms. have to make time to put them all on
Old May 19, 2012 | 11:00 PM
  #65
Engine: sbc 383
Transmission: Th400
Awesome! Goodluck and keep us updated!
Old May 20, 2012 | 06:32 PM
  #66
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
well i decided to put a th350 in that we have laying around instead, it still has a 4k stall and just a shift kit.
the money i was planning to spend on a tranny will now be going to the powerjection 3 setup and soon a 76mm
Old May 21, 2012 | 07:34 PM
  #67
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
well its set in stone now, i ordered a walbro 255 with install kit and a turbo xs bov.
i think that a 38 mm will be enough to hold the pressure.
im thinking either a s475 or mp t76 q trim.
also ordered my tanny cooler, umi crossmember with torque arm relocation and a poly bushing.
will a 38mm gate hold the s475? if so ill go that route as i can get an emusa for 50 bucks new and back when i was into dsms the community swore by them
Old May 24, 2012 | 09:16 PM
  #68
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
i managed to get the 350 in, i just used a 3k stall because i want to drive it a LOT on the street. i used the bmr torque arm relocattion crossmember. it is a very nice piece and fitment is right on. the way it is designed you dont need an adjustable torque arm, it has literally like 10 different locations to mount it up and down. i put the torque arm in the middle and i will adjust from there.
will also be throwing the founders performance lca's and lcarb's on soon also.
i will be getting the powerjection system very soon, was going to be this week but... you know the usual bills. so 3 weeks from now it will be ordered.
ill keep the car n/a this year and turbo it next year, this way i can gather all the parts.
ill post pics up after its all done.
i will probably do a write up for the 350 swap so people can use it for future reference.
anyone looking to do the swap- stock driveshaft will work, it needs to be lengthened exactly 5 inches and it will be perfect.
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mike22115
Sep 28, 2015 04:49 AM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
