has any one ever done a 4.3 v6 swap in a firebird
Old Mar 30, 2012 | 02:50 PM
kcaalarcon's Avatar
i have aquired a tbi 4.3 v6 outa a 92 gmc pickup and im probly gonna turbocharge it and swap it in my 88 bird for the stock 2.8, has anyone ever done that swap
Old Mar 30, 2012 | 05:08 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
re: has any one ever done a 4.3 v6 swap in a firebird
https://www.thirdgen.org/forums/engi...questions.html This one was a few lines down
The 4.3L has the same bolt pattern on the front and black as a 1-piece RMS 350. so you would need the accessories and a transmission that will fit to a 350.
motor mounts. These mount to the same place as your 2.8L
http://www.summitracing.com/parts/TRD-4626/
http://www.summitracing.com/parts/TR...n/?prefilter=1
What you want to do with the fuel injection is up to you
Old Mar 30, 2012 | 08:43 PM
kcaalarcon's Avatar
i have a 200-4r trany so it should bolt up, im not sure what im gonna do for my efi system yet cuz none of the aftermarket system will work with turbos so im thinkin about a piggyback ecu and some extra injectors
Old Mar 31, 2012 | 04:40 AM
Car: 86 Camaro Z28
use a syclone/typhoon intake, that's what I would use. I don't know how well the 200-4r will hold up. you can probably get a 700 out of a salvage yard for 200. That's not saying that the 700 will hold too much either
Old Mar 31, 2012 | 12:01 PM
kcaalarcon's Avatar
ive actuly heard of the 200 holding up better but i also have a couple 700s to blow up to, eventualy i want to do a t56 and a gear vendors gear splitter. any idea where i can get a a manifold from a typhoon or cyclone?
Old Mar 31, 2012 | 04:26 PM
Car: 86 Camaro Z28
either ebay, s/10 blazer forums and syclone/typhoon forums
2out_The_Left
Oct 26, 2004 08:37 AM
Camaro Project
Jul 9, 2004 09:10 AM
85_ZED28
Dec 18, 2002 09:03 AM
LS
Jun 8, 2001 03:50 PM
