sb2.2
Old Apr 11, 2012 | 12:41 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
sb2.2
Does anyone know if the SB2.2 heads will fit an old school 350 or 400 SBC block? If so what is involved in the making it work correctly like offset lifters, distributor.
Old Apr 11, 2012 | 01:38 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: sb2.2
I don't know enough about SB 2.2 heads to know whether they can physically work with a conventional block or if they need an SB2 block, but from what little I do know, it's not a "bolt on" regardless. The valve spacing requires a completely unique cam billet with modified lobe spacing. The revised valve angles and positions will require unique pistons as well, and due to the massive flow that the heads have, you should be looking at very large cubic inches or very high rpm in order to utilize any benefit from them over a more conventional set of heads, which of course brings along a whole other set of issues regarding component strength, etc.
And then there's headers...
Old Jul 25, 2023 | 09:11 PM
Tombowman89's Avatar
Car: 88 Iroc
Engine: 388 Vortec Pro-Flo 4 Small Block
Axle/Gears: 3.77 to 1
Re: sb2.2
At an absolute minimum you need a 4.125” bore block with a 4.400” bore spacing.
I’ll revive an old thread, I’ll show you everything to make SB 2.2 heads work and fit in a Third gen Camaro and run fast as heck
Confuzed1
Feb 2, 2014 11:55 AM
Shadyredeyes
Feb 10, 2012 06:56 AM
CamKid1992
Jan 18, 2010 12:45 PM
jrg77
Dec 1, 2005 10:54 AM
5.7Camaroboy
Jan 20, 2003 11:17 PM
