Fuel line fiitings/adapters question
Old Apr 17, 2012 | 11:19 AM
R3500's Avatar
Tried looking locally and online...but not having luck identifying (by description) what fittings I need. Trying to plumb up the fuel in and return lines to a TPI engine. Have the OEM TPI fuel lines from the fuel rail down to the frame and want to use a fuel cell with 8 AN supply and return male fittings, to a filter (before or after pump), then Ford style inline pump and to the stock fuel lines.
The GM push/pull fittings work on the Ford pump...what are the description names of the fittings I need for the supply and return lines?
Also: Looking at the Speedway catalog they have "push on" blue or black hose systems..anyone use the system?
Old Apr 20, 2012 | 07:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Fuel line fiitings/adapters question
GM fittings with the O ring are " METRIC O ring "
Confirm sizes ; supply line is 16mm , on early cars return is smaller (14mm )
http://www.summitracing.com/parts/RUS-640830/
http://www.summitracing.com/parts/RUS-640820/
Why so big if only using the factory (-6AN ) lines from the frame
Most would say run the new lines all the way to the rails and use this fitting there to adapt AN lines
http://www.summitracing.com/parts/RUS-648060/
http://www.summitracing.com/parts/RUS-648070/
Great for budget use , cheaper hose (still rated to similar operating psi ) and simpler install BUT;
once the hose is on the barb it will not come off short of using a box cutter
So measure twice / cut once
Old Apr 20, 2012 | 09:49 PM
R3500's Avatar
vetteoz
Thanks for the response...I suspect a bunch of folks didn't know the descriptions.
I'm good to go now, the reason I wanted 8 AN is because the fuel cell uses male 8 AN supply/return. The electric fuel pump is also 8 AN on the inlet side. Want to keep it 3/8" from the tank, through the filter and then to the pump...and have since identified the parts I need.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
