350 swap questions
Old May 11, 2012 | 11:41 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
350 swap questions
I have a 1991 camaro rs that i was planing to put a corvette engine in but its becoming expensive and Im going to try and put a 355 four bolt main into my car while waiting to finish the other motor. Its going to be a mild build because its my daily driver so Interested to find out if i can use the same harness with a 350 computer or not and what type of cam should i use for the tbi to work properly and if i could use the 305 heads i have know or will that raise the compression to much and if so what set up can i use to make good power but still be able to drive it. I already have a 0.30 rotating assembly from jegs but thats all at this point.
Old May 11, 2012 | 06:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 swap questions
https://www.thirdgen.org/forums/engi...350-bored.html
Old May 13, 2012 | 10:32 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
Ok that tells me about the heads but what about the 305 wiring harness with the 350 computer and what mild cam i can use to make it act right but give it some power as well with the tbi
Old May 13, 2012 | 10:37 AM
VinnyX40's Avatar
Car: Camaro RS
Engine: TBI 305 H.O
oh yah and with aluminum heads if i did go with them, have to have a reverse flowing water pump because the heads would expand faster than the block? or is that just for lt1's
Old May 13, 2012 | 10:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd have to have a reverse rotation pump because the pulley turns backwards on a serpentine belt setup. Nothing to do with aluminum heads.
LT1s run the coolant through the heads before the block by design. Completely different system.
Old May 14, 2012 | 01:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't put 305 TBI heads on a 350. The linked thread assumed LG4/LU5/L69/LB9 305 heads.
Frozer!!!
Jan 19, 2024 04:55 PM
bellez77
Sep 5, 2015 08:39 PM
redmaroz
Aug 16, 2015 11:40 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
