305 heads on a 350 bored to 383
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: 305 heads on a 350 bored to 383
absolutely not
305 heads barely flow well enough for a 305, and are very flow challenged on a 350... on a 383, it would be terrible
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Bigger engines need more air to make HP. Not all castings are the same and there are a few good 305 head castings. They're good for bumping up compression but if they can't flow enough air into the engine to make power, higher compression is useless.
Aluminum heads have become very affordable. Buy some good aluminum heads and you can feed the bigger engine plus reduce a bunch of weight. If aluminum heads are not in your budget, a set of 350 Vortec heads will be much better than 305 heads.
Transmission: 4L80E/4L80E
For the record, you can't bore a 350 to 383. You have to increase the stroke and bore 0.030" over (unless you do like GMP and use a 3.80" stroke & 4.000" bore).
The LG4/L69/LB9 305 heads with 1.94" intake and 1.50" exhaust valves will flow as well as L98 350 heads. With decent port/bowl clean-up and 1.60" exhaust valves, they'll flow even better. You can support a mild 383 that way.
But, by the time you did all that to 305 heads (especially if you paid somebody to do all the work), you're most of the way to decent aftermarket heads.
New to this forum, but for the record all you need for a 383 is to punch the 350 out .030" over, and put a MODIFIED 400 crank in. and VOILA!!! you have a 383
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which would be the stroke increase that five7 mentioned, but nobody uses modified 400 cranks anymore.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 87 IROC L98
Plus to make an old school 383 with a 400 crank, you also need to use the 400's shorter rods to work with the 350 pistons. Now everybody uses the more common longer 350 rods with stroker pistons which locates the wrist pin higher.
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
The old school 383 also forces you to a 2pc rr seal and could get interesting in finding a standard flywheel.
Not really. They are readily available. Expensive, but readily available.
NinjaNife
Aug 23, 2015 11:49 AM
