3.1 tpi to 5.7 carb swap and build.
Car: 1992 Firebird
Engine: 3.1L(swapping in 385)
Transmission: Looking for T56
Axle/Gears: Looking for 3.73 posi
I have a carbed 350 that came from an 88' IROC and a 700r4 trans from a caprice police car. The research I've done tells me somebody took an older truck engine and put it in their car. I'm planning on building this engine as strong as I can for the money I have but I want to make sure I get everything that will work together. I'm not completely sure of my budget yet, most of it is graduation money I will be getting soon. I will have a better idea of my budget within a week. As of now it's looking as wide a range as 7-9k. I have 6k of my own right now.
I'm looking to: put a nice size cam in for performance, rockers, lifters, maybe aluminum heads if I can, a good intake, a good size carb(heard Holleys are best but haven't decided size), should I replace radiator? would like to put posi rear in(need help with what gears would be best), flat top pistons? quality water pump I should use, do I need to replace front springs? headers, etc.. I know there's more but I haven't started yet.
I have the 350 stripped down to just pistons, crank, cam, and timing set. I plan on removing everything to bare block when we get our tools back and then get everything I need to build the engine and swap it in. Please be patient with me, this is my first v8 swap. I just wanted to start this thread as I do a complete engine and trans swap(along with rear) over summer and start getting ideas on what I should do.
Edit: Also want to mention this is a daily driver, but only short distances. I don't want to go too crazy and make it a strip only car. I just want to have a street car that will get up and go.
Car: 1992 Firebird
Re: 3.1 tpi to 5.7 carb swap and build.
My block casting number is 10054727(350...86-up...2 or 4...one piece rear seal, some "Made in Canada"). Casting Date is L 07 8(Dec 7th 1988 for model year 1989). Engine Code: K1115TPA(for a ‘92 350cid truck 210hp L-05 tranny TBI). Head Casting is 14102193(87-up... 305/350...... 1.94"/1.5" valves). That's all I could find.
With that said, I was thinking putting aluminum heads on with hydraulic roller cam, roller lifters, and valvetrain and rockers that agree, Holley carb, selling 700r4 and buying a manuel transmission, quality pistons, possibly radiator upgrade.
I know there is a lot more to get but I'm still trying to make up my mind on some thing. I haven't decided what brand or type of heads or cam. I'm not sure I can put a hydraulic roller cam in this block. I can't figure out what to get with pistons. Also haven't decided on 5 speed or 6 speed. Any help and/or ideas would be appreciated. Thanks
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Top of engine swap page
V6 to V8 Swap - READ BEFORE POSTING NEW!
https://www.thirdgen.org/forums/engi...swap-read.html
Car: 1992 Firebird
Right now I'm researching a lot about this engine and trying to put together a list of things to do to/ put on it. But if anyone would like to put suggestions for parts or things to do, please do.
Car: 82 Z28
Transmission: T400
Ask or review the multitude of engine building posts in 3rd Gen Engine
https://www.thirdgen.org/forums/tech-general-engine/
Questions posted and answered daily on what / how/?? about builds
Sanjay
Aug 12, 2015 03:41 PM
