906 Vortec heads, cam lifters advice
Old Jun 2, 2012 | 03:37 PM
IroczFan's Avatar
Car: 86 IROC-Z
Engine: 383 Stroker Vortec
Transmission: 700r4 Built
Axle/Gears: 3:42
I found a pair of 906 vortec heads for $300 i wanna use on my 350 build im usings a 70s era block so with the vortec heads do i use a roller cam with lifter or flat top cam with hydrolic lifters?
Old Jun 2, 2012 | 04:53 PM
1gary's Avatar
Re: 906 Vortec heads, cam lifters advice
You would have to convert to a roller cam which those kits are expensive.
Old Jun 2, 2012 | 10:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Heads don't care what cam / lifters you use but your block is a flat tappet block
Old Jun 3, 2012 | 12:46 AM
IroczFan's Avatar
Car: 86 IROC-Z
Axle/Gears: 3:42
so i could use them vortec heads with a flat toped cam and hydrolic lifters right?
Old Jun 3, 2012 | 01:36 AM
1gary's Avatar
Yes you could.The roller hydro conversion kits cost kind of work out to you could find a good roller block for less than it costs for the kit.Most good shops have moved to put pressure on their customers to use a roller cam engines because the lack of additives in today's oils which create flat tappet cam failures.You can use a additive during break-in of the cam,but I suggest you continue the use of a additive in every oil change through out the life of the engine.
84z96L31vortec
Aug 20, 2017 12:16 AM
Mickeyruder
Sep 2, 2015 02:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
drathaar907
Aug 6, 2015 04:20 PM
