350 upgraded injectors
Old Jun 13, 2012 | 12:01 AM
Zachnoel's Avatar
Hi,
I am doing some upgrade to my 350 TPI. I am adding VORTEC heads, shorty headers, extreme energy comp roller cam, large runners and aftermarkets throttle body. Will I be making enough HP that I will should upgrade my fuel injectors to 24.9lb or will the 22lb injectors be ok?
thanks
Old Jun 13, 2012 | 02:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.watkinsmotorsports.com/Fu..._required.aspx
You may want to go larger to avoid going 100% duty cycle.
Old Jun 14, 2012 | 10:52 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: 350 upgraded injectors
Another alternative is to install an AFPR and bump your pressure up a tad.
Old Jun 14, 2012 | 11:50 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Bump up your fuel pressure until your INT/BLM are averaging 128 BLM. To be honest though, with these types of upgrades, duty cycle and the air/fuel ratio aren't the only thing you should be concerned about. I would look into a better prom because your Acceleration Enrichment as well as your Spark Advance will need some tweaking to maximize those modifications...
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
