Quick VATS LT1 Question
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
Will ripping out the factory VATS box effect my ability to run my LT1 which has it's computer VATS tuned out? Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Quick VATS LT1 Question
the injectors will not fire unless the vats has been reprogramed out of the memcal 93 only 16159278 94-95 flash based ecm 16181333 or 16188051.
Car: 1987 IROC
My computer has already been tuned for the LT1. I'm concerned about the VATS box I removed from the 89 car.
Engine: Lb9
Transmission: M20
did you have the vats reprogramed out of the ecm ? If so the passkey module can meet the dumpster.
