fuel injected to carb
Car: 1984 z28
Engine: 305 for now
Hey guys I have a 1984 camaro that I am changing over to carburated and I am gonna use as a track car and occasionally a cruise down the road. I am wanting to remove all the wireing that was there from the fuel injection and looking for some advice on how to do so or maybe a wireing diagram that shows what I can take out. And any other tips to clean up the engine compartment any advice is very appreciated thanks
Car: 1984 z28
Engine: 305 for now
Re: fuel injected to carb
Cfi?? I just wanna get to the bare minimum as far as wires and stuff go but not real sure what to remove
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
cfi =Cross Fire Injection , If you are going to a carb you will need a fpr. all the fi wiring can go you will just be left with the charging system, starter wire and power wire to the distributor and tach wire if equipped.
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
CFI
