Cam schooling appreciated and wanted!!!
Old Jul 27, 2012 | 08:41 AM
lameusername's Avatar
Any and all input is greatly appreciated. I'm shopping for cams. The only thing I think I understand is about the intake/exhaust specs. For instance, I think I need to be less than .500 for my stock l98 heads??? (By the way, It's a TPI set up.) But if that's wrong then tell me. I don't mind suggestions, but tell me why you suggest something. I also know I can call up comp cams and get a suggestion. But I'm an electrical engineer and love to come up with my own stuff. I'm someone who wants to know why and take pride or responsibility for what I've chosen. Any info on lobe, exhaust/intake when I need to upgrade my heads, the whole nine. Thanks you all in advance for your input!!!!
Last edited by lameusername; Jul 27, 2012 at 08:42 AM. Reason: Forgot to add TPI set up to my post
Old Jul 27, 2012 | 11:15 AM
1gary's Avatar
Re: Cam schooling appreciated and wanted!!!
I use ref links because they are written better than I could:
http://www.enginebuildermag.com/Arti...ng_basics.aspx
http://www.camtechniques.com/Pages/term.html
http://claysmithcams.com/index.php?r...tegory&path=96
Old Jul 27, 2012 | 01:41 PM
Thanks a lot!! I'll look into these links for sure!!!
Old Jul 27, 2012 | 02:07 PM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
It all depends on what your goals are for the car. If you plan on doing heads in the future, they may produce more power than a cam you put in for your current heads. What year is the car/motor? Is it a roller or flat tappet?
Old Jul 27, 2012 | 07:44 PM
My over all goal is just a nice respectable street machine with more torque than horse power in mind. If that makes any sense. I want to smash the pedal and see people in my rear view getting smaller than to reach 160mph. As far as heads, as of right now, if I do anything with or to them it will just be a port/polish.
Old Jul 27, 2012 | 07:45 PM
Oh, I forgot to mention, I have an 86' top end with a 91gta block tpi set up.
Old Jul 27, 2012 | 08:01 PM
1gary's Avatar
Please read cam choices thread and look at the Richard part of it.Compression ratios matter before cam choice.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Dquickshift
Aug 12, 2015 06:21 PM
