Not a firebird, but pointaic and sbc swap power steering hose question
Old Aug 5, 2012 | 10:25 PM
nickyakker's Avatar
Car: 1982 Firebird T/A
Ok, So im taking over someones project thats on hold. Its a 70's pontiac ventura that had a v6. The v8 is alrady installed but the power steering pump wasnt hooked up. I mounted the pump, the pump has both hoses attached (with o-rings still attached), and the old hoses from the v6 are still attached to the steering column. SO! hoses are different. the old V6 power steering hose doesnt have the o-ring fitting. Havent pulled it off the column yet but i suspect that fitting wont have the o-ring either. If it doesn't, what do i do? Do i try and find a sbc power steering pressure hose that has the 0-ring for the pump and no o-ring for the column?
Old Aug 7, 2012 | 01:34 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Not a firebird, but pointaic and sbc swap power steering hose question
The best way if the V8 hose is long enough is to take both in to a hydraulic hose shop and explain what you need. Should be able to take the end fittings off and swap what you need with a new crimp connector. They might say they can do it only if you have the crimp connectors and end fittings off. A little time with a grinder and pliers and the fittings can be off without damaging the hose. Then more time to clean up or finish grinding to old crimp connector off.
Good Luck.
Old Aug 8, 2012 | 07:17 PM
nickyakker's Avatar
thats what i was suspecting, thank you for posting the reply. appreciated
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
