software 91 chevy
Car: iroc z
Engine: 383 in the works
Axle/Gears: 3:73
Re: software 91 chevy
$42 definition ?
http://www.tunerpro.net/downloadBinDefs.htm
you can buy everything from moates.net for 28 pin conversion
http://www.moates.net/g2-memory-adap...g-spacing.html
i don't wanna change the prom ..i know its possible to play with date without changing the prom ...a guy around here is doing it but i lost his phone number ...any cable from laptop to the connector available ..is it a easy software ??
Car: iroc z
Axle/Gears: 3:73
play with date
are you looking to just data log
Car: iroc z
Axle/Gears: 3:73
sorry I don't understand what your asking You might try posting in the correct forum section to get help. If you are asking if you can just data log the ecm data stream you just need the appropriate program and cable. winaldl , tuner pro ect..
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
To change parameters with OBDI, you need to burn a new prom. OBDII allows you to change parameters by flashing the ECM.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
