engine swap.. 334, 327 or 350
Car: 1991 rs camaro
i just picked up my 91 rs camaro with a 305 for 4 grand. damn near perfect shape. i really want a 327 or a stroked 305... whats the best engines to start with for each build? i know vortec 350s are good, but is a vortec 327 good also?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: engine swap.. 334, 327 or 350
The smaller the cubes, the worse the bang for the buck. It will cost you more to build a 334 than it will to build a 350, and it will perform much worse, especially considering the small bore size, which will seriously limit cylinder head selection.
Build a 350 or 383. Anything smaller is just a waste of money for the sake of "uniqueness".
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Can't do a 383 as a Junkyard Jewel, but if you're gonna do a build, the same money is better spent on a 6.0 or turbo 4.8 than a 383. Still more cost than a JJ 350, but more results after the investment.
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
