tbi to tpi issues having brain fart!!
Old Oct 18, 2012 | 08:35 AM
ChrisM89's Avatar
Can anyone tell me what I missed I have an 86 Iroc with a tpi and a 91 with a tbi both 305s so i have a good understanding of both motors but i just changed my tbi to tpi everything went well till i started it. It starts but only with starter fluid, pump works, car will run but its dumping too much fuel into exhaust .Car runs but when u hit the gas it huts off . Motor came out of a 92 camaro and was set up for speed density everything was there. Im stumped if theres anyone that can give me a few ideas i would love the help thanx.
Old Oct 18, 2012 | 10:32 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tbi to tpi issues having brain fart!!
If it's running that rich you might have leaking injectors or a tear in your fuel pressure regulator diaphragm. What is your base timing set at ?
Old Oct 18, 2012 | 11:14 AM
ChrisM89's Avatar
Thank u for the info ill check both,I dont know what the timing is set at I had someone set it for me.I have another set of injectors from my 86 will they work in a 92 if not ill just buy new ones hey thank u for the help.
Old Dec 6, 2012 | 10:23 AM
combatdoc's Avatar
Car: 91 z28, 92 ZR1
Engine: LS1, LT5
Transmission: T56, ZF
Axle/Gears: 3.73/ 4.10
you ever get that TPI to run right? I did that swap as well 92 rs 305/t5 to SD 355 TPI was very easy all I had to do was re-pin the c100 for the speedo
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
Wade787b
Sep 29, 2015 01:15 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
