hoist question
Old Dec 3, 2012 | 11:23 AM
johnw999's Avatar
hoist question
1. Any recommendations for the type of engine hoist that I should use?
2. I've seen some pictures where the nose of the car was removed during engine install. Is that necessary?
3. Is it possible to install a 350 engine with a t56 already bolted to it?
Old Dec 3, 2012 | 12:35 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: hoist question
1. I bought the cherry picker from harbor freight for $200. It worked great. It had the extension type boon.
2. Nope it should work fine if you get one where the boon will go out far enough. Just mark your bracket alignment and remove the hood of course.
3. Maybe, but you'd probably need to get one of those fancy crank style levelers and have the car a long ways off the ground. I just bolted up my 700-r4 after I put the motor in.
Old Dec 3, 2012 | 01:24 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: hoist question
Some hoists have more reach than others. I would suggest you measure how much reach you need before buying one. Some of the cheaper ones won't reach without removing the nose piece. I bought an old used one off craigslist that has plenty of reach and is nice and heavy. Keeps the back of it from coming up when its loaded down.
My car is an automatic but I've pulled the engine and trans together many times. Its a lot easier if you use an engine pivot plate. Costs a little bit more than the normal load leveler but its easier to use. One of the best tools I've ever bought! I just read on the website they make one for both carb and TPI.
http://myks-tools.com/
Old Dec 3, 2012 | 03:10 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: hoist question
I have/recommend an older US made hoist, which will most likely be too short. But, pulling from the side is an option.
Attached Thumbnails hoist question-dscf1741.jpg   hoist question-dscf1746.jpg   hoist question-dscf1757.jpg
Old Dec 3, 2012 | 05:02 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: hoist question
+1 on going from the side
Old Dec 3, 2012 | 06:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Or pull the body up away from the engine...
Old Dec 4, 2012 | 02:34 PM
watajob's Avatar
Car: 92 T/A 'vert
Re: hoist question
I'd actually like to see/help do this once. It just strikes me as a whole bunch more work. I'm probably just being stubborn but I dunno'...
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Hello, Michael
Aug 20, 2015 03:19 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
