Vortec head gasket question??
Old Dec 10, 2012 | 12:05 PM
bigtizzles's Avatar
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
I'm swapping in a Gen 1 sbc with vortec heads into my 89 RS. I was wondering what kind of head gaskets you guys are running with your vortec heads? Stock vortec compression was like 9.4 i believe, so if my motor is under 10.1 (probably around 9.5) will I be ok to use a stock vortec head gasket? I don't see what the problem would be. What do you guys think??
Old Dec 10, 2012 | 05:13 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Vortec head gasket question??
Unless the block has been decked, use FelPro 1094 rubber-coated steel-shims for best quench and least detonation. The goal is 0.035" - 0.045" piston-to-head, and stock pistons are supposed to be 0.025" in-the-hole at top dead center, but usually check between 0.020"-0.035", so the 0.015" FelPros are ideal. Thicker gaskets drop the static compression, but the loss of quench makes detonation more likely.
Old Dec 11, 2012 | 07:43 PM
bigtizzles's Avatar
Engine: 327 sbc
Transmission: TH350
The heads were milled just enough to clean up the gasket surface to get a good seal. Its a 327 block so I don't know what the piston to head clearance should be. Don't I need a vortec specific head gasket, or can I just buy a Gen 1 set of gaskets? I was under the impression I needed a gasket for the Gen III vortec? Maybe I'm just a noob
Old Dec 11, 2012 | 07:48 PM
bigtizzles's Avatar
Engine: 327 sbc
Transmission: TH350
nevermind, i'm an idiot. For some reason I thought I had to use a head gasket made for the vortec heads. So when I would search for "vortec head gasket" I would get limited results, mostly stock replacements.
Old Dec 13, 2012 | 02:27 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
on the 355 in my Nova, i ran the thinnest shim gaskets that Mr Gasket makes- .015, i think- sprayed with a good coat of the gold sealer stuff on each side.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
NinjaNife
Aug 23, 2015 11:49 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
