305 to 350 Swap
Old Feb 13, 2013 | 10:47 PM
McChoka's Avatar
Car: '82 Z28
Transmission: TH-350
Axle/Gears: Posi
305 to 350 Swap
I'm (obviously) doing the swap. And before I get in too deep (all I've done so far is unhook the 350) I wanna know if anyone has some hints or tips from personal or past experiences that would help me out. Thanks
Old Feb 13, 2013 | 11:17 PM
kenwood1609's Avatar
Car: 1989 firebird formula
Re: 305 to 350 Swap
Be careful when removing the 305 and make sure not to break any sensors I made that mistake and now im paying for it.
Old Feb 13, 2013 | 11:20 PM
McChoka's Avatar
Car: '82 Z28
Axle/Gears: Posi
Re: 305 to 350 Swap
Where are the sensors at that I should be careful with?
Old Feb 13, 2013 | 11:24 PM
jdogg15j's Avatar
Car: 1989 Camaro Rs T-top
Engine: 5.7 tbi
Axle/Gears: 1005429 from and 89 gta/ 3:27's
Re: 305 to 350 Swap
What is the 350 coming out of? Is your 305 tbi? Is the 350 tbi or tpi? Either or make sure you grab the ecm from whatever the 350 is coming out of. I did a tbi 350 from a 1992 suburban into my 1989 camaro. Mind you, I was still running factory tbi ecm with camaro harness. I just switched the ecm only to the burbz ecm and now it doesn't run rich anymore.
Old Feb 13, 2013 | 11:26 PM
jdogg15j's Avatar
Engine: 5.7 tbi
Re: 305 to 350 Swap
He talking about the sensors on each side of your engines. Drivers side is coolant and passenger side is the knock sensor.
Old Feb 13, 2013 | 11:35 PM
McChoka's Avatar
Car: '82 Z28
Axle/Gears: Posi
Re: 305 to 350 Swap
Both are have carburetors. No injection in these. Its just a lot simpler to work on for me.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
