Stock 1991 3.1L V6 Camaro
Old Mar 8, 2013 | 12:41 PM
ZavalaCarpets's Avatar
Car: 91rs
What can I do that isn't an engine or transmission swap that would make my car drive better? The car has been sitting for a few years. But drives. Doesnt have a steady idle
Old Mar 8, 2013 | 01:58 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Stock 1991 3.1L V6 Camaro
Is there a "hissing" sound in the area of the vent-controls behind your dash?
Old Mar 8, 2013 | 02:13 PM
Car: 91rs
No, it does make a hissing sound when I turn off/on the ac.
Old Mar 8, 2013 | 02:15 PM
Car: 91rs
Cab it be the timing? Since the car hadn't been moved in awhile? I've done a tune up, spark plugs, wires along with new starter and alternator
Old Mar 9, 2013 | 09:29 AM
ex-x-fire's Avatar
Bad gas?
Old Mar 9, 2013 | 09:54 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
A Tune up?
A lot can/ needs/ should be done to a car that has been sitting for a few years.
Change all the fluids, new filters, plugs, wires, cap rotor, basic tune up stuff.
Drain gas tank. Run Sea foam through it.
Replace any questionable hoses.
Old Mar 9, 2013 | 09:56 AM
Car: 1971 Camaro
Engine: 427
Did you change Dist. Cap and rotor? PCV Valve? Air Filter?
Timing should not 'move' from sitting, but should always be checked as part of a Tune up. Just changing spark plugs is not a tune up.
blackz281le
Jan 11, 2016 07:51 AM
Night rider327
Oct 9, 2015 09:25 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Vincent135
Sep 28, 2015 10:50 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
