please help
Old May 5, 2013 | 10:56 PM
90_camaro's Avatar
please help
I have a 1990 camaro r.s. its an auto tranny (700r4 over drive) it originally had a 5.0 I swaped it for a 5.7 and now it won't run right it seems to be running to rich I've changed everything from, ( ECM computer, ignition module,rebuilt the throttle body,new o2 sensors, new plugs and wires and yet nothing helps. Looking for some other ideas.
(Car symptoms)\/
Has bad hesitation when accelerator is put to the floor. (About 6 sconds)
Is reqlly jumpy when at a red light or stop sign (like its going to stall but doesnt
Very jumpy tac
Smokes light black (not alot of smoke barley visible)
Lost ablut 30% of its power
Old May 5, 2013 | 11:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: please help
Have you hooked up a scanner and watched the coolant temperature sensor and map ?
The 350 requires more fuel and runs lean unless you swap to tbi truck injectors and have a new calibration made for the ecm.
Old May 5, 2013 | 11:06 PM
90_camaro's Avatar
Re: please help
How do I get it calibrated
Old May 5, 2013 | 11:14 PM
Engine: Lb9
Transmission: M20
Re: please help
You have alot of options, tbi chip.com, PCM for less . Did you upgrade the injectors ?
https://www.thirdgen.org/forums/engi...sion-prom.html
Old May 5, 2013 | 11:16 PM
90_camaro's Avatar
Re: please help
I think so I ordered ones for , caprice , camaro, fire bird, it said they are higher performance injectors
Old May 5, 2013 | 11:22 PM
Engine: Lb9
Transmission: M20
Re: please help
If there were ordered for a caprice 350 the flow rate is higher the pegs when the injector wires go will be orange for 55#hr injectors.
Old May 5, 2013 | 11:28 PM
90_camaro's Avatar
Re: please help
The wires are green yellow. Red and blue and the clips are a brownish orange
Old May 5, 2013 | 11:33 PM
Engine: Lb9
Transmission: M20
Re: please help
Old May 5, 2013 | 11:42 PM
90_camaro's Avatar
Re: please help
I tried posting a pic but dnt no how. There the exact same as the pic u posted. That is the correct one?
Old May 5, 2013 | 11:45 PM
Engine: Lb9
Transmission: M20
Re: please help
Yes those are the correct ones, they identify them with the manufactures part number and gm colored the terminal legs orange like the picture would be correct.
